Repairs for X3 camera
1816 8 2016-8-20
naildrivingman
Flight distance : 112451 ft
I have two Ver 1 X3 cameras that suffered hard landings.  As near as I can tell, the damage to both cameras is identical:  broken main arm and torn/severed ribbon cable.  I was referred to Jeremy at US Drone repair, but I did not act quickly enough.  He is out of parts and likely will not be getting more soon.  Can anyone give me other recommendations than sending directily to DJI.  I've been down that road before and the turnaround time was very long.
Thanks,
Chris
2016-8-20
vonbaron1
Flight distance : 42014 ft
Sent mine in for repairs on 4/9/16.  Got a tracking that it will be back on the 24th.   Sure cannot complain about that.  Good Job DJI
2016-8-20
naildrivingman
Were you able to send just the camera unit or did they want the whole kit?  If I can send just the camera, then I will do so.  Let me know.  Thanks for the reply.
2016-8-21
naildrivingman
The last time I had an issue was with the bird and it took 12 weeks to complete and return to me.  That's my concern.
2016-8-21
markaguille
Flight distance : 2290810 ft
Jersey
vonbaron1 Posted at 2016-8-20 23:49
Sent mine in for repairs on 4/9/16.  Got a tracking that it will be back on the 24th.   Sure cannot  ...
Hi Vonbaron,
How much did they quote you for repair?
Mark G.
2016-8-21
DJI-Jamie
DJI Team
Flight distance : 112405 ft
naildrivingman@ Posted at 2016-8-21 21:01
The last time I had an issue was with the bird and it took 12 weeks to complete and return to me.  T ...
The turnaround time has improved since then. Depending on where you are located, turnaround times have been roughly 1-2 weeks.
2016-8-21
SimplePanda
Flight distance : 1719062 ft
vonbaron1 Posted at 2016-8-21 06:49
Sorry, you sent a gimbal for repair in April and you're getting it back on August 24th?
2016-8-21
vonbaron1
I sent just the bird in. No camera, batteries or remote.  Quote was 370.  Bird was bend out of shape from the crash but everything else worked except the gear was binding when going up or down.
2016-8-21
naildrivingman
I have two cameras and I just sent them in today.  DJI told me 1-2 weeks turnaround.  Both cameras broke due to hard landings (my fault) on uneven surfaces (again my fault).  The main arm that the camera hangs from broke and the internal ribbon cable tore.  I'm pretty sure nothing else was damaged.
Anybody have this same issue and if so any input on repair costs?  I guess it doesn't really matter at this point, because it is going to cost what it will, but I would like to prepare myself for the out of pocket as soon as possible.
Thanks.
2016-8-23
