HDMI issue
782 4 2016-8-20
PartsGuy
Flight distance : 418346 ft
Tried out my new HeadPlay FPV today. I put them on my wife and did a brief flight. Had almost constant issues with lag, freezing screen and green screen on my Ipad mini 4. Anybody got an idea of what's going on? The HeadPlay was perfect. No lag or freezing. I've flown without the FPV before and after I installed the HDMI. Didn't have any issues. I can't think that the HDMI out would affect the Mini 4 since they are two different outputs unless the radio can't process two signals fast enough.
2016-8-20
Heebus
Have you enabled simitanious image output in the app, I have read some have had to uninstall and reinstall the app to make it show up
2016-8-20
PartsGuy
Heebus Posted at 2016-8-20 20:20
Have you enabled simitanious image output in the app, I have read some have had to uninstall and rei ...
It showed up fine and I enabled it. The issue is just with the Ipad mini 4. The FPV works fine.
2016-8-20
DJI-Paladin
Flight distance : 2408 ft
PartsGuy Posted at 2016-8-21 10:48
Have you enabled Hardware Decoding in your Go app? Was your mini4 hot at that time?
2016-8-21
PartsGuy
DJI-Paladin Posted at 2016-8-22 00:15
Sorry for the long time to respond. I haven't had time to play with HDMI but I flew today and had the same issue with the Mini 4. i turned off hardware decode and it went away although it seemed there was some lag, I didn't get the screen freezing and green screen. I checked the version on the Ipad and it says 9.3.4 (13G35). Any ideas why turning off the hardware decode would make it better? This flight like the HDMI flight was close. In my yard at about 60ft away and 40ft in the air.
2016-8-28
