Inspire 1......Pro FW?
1197 10 2016-8-22
taborproduction
Does the Inspire one and Pro use the same FW?
2016-8-22
DJI-Jamie
Flight distance : 112405 ft
As far as the aircraft itself, yes it's the same firmware. The difference in the two .bin files lies in the data package for the camera. The Inspire 1 specific download would have the firmware for the X3 camera, while the Inspire Pro download would have the firmware for the X5. If you solely have the Inspire 1 Pro, that is the .zip file you want to download. If you also have an X3 camera, then you would use the Inspire 1 specific .zip file to solely update the camera. The aircraft data packet would be skipped during the update process if that is already updated to the latest firmware.
2016-8-22
Donnie
Flight distance : 3636782 ft
I love  DJI Jamie but I would just  say  to avoid future pain and suffering ASSUME   that they are not compatible ,  The Inspire  1  uses  certain  firmware The Pro and the Raw use different firmware as well.  ( Pro and X5 ) = pro firmware    (Pro and X5 Raw )  Raw firmware    ( Inspire 1) X3 camera uses Inspire firmware ( Not the X5 or Raw etc. )
I have seen this a hundred times, where the Pilot  who owns and Inspire 1 ( with x3 )  downloads the Inspire Pro ( with X5 )  software and has all kinds of trouble .  AND ALWAYS UPDATE THE AIRCRFT FIRST ! BEFORE THE RC IF THERE IS AN UPDATE TO BOTH SYSTEMS.
Triple check that you are using the correct version for your system.
DJI -Jamie is correct by the way, I am just saying for you and others lurking , that be sure to load the correct version for your system , and triple check it is the correct one.  It is simple to confuse them.
donnie
2016-8-22
taborproduction
I've spent the last 6 hours "chatting" with DJI. Absolutely no help. Now I must take to someone to fix it, and pay for it myself or return it AGAIN! 3rd time!
3 new drones. Not one of them worked.
They can't understand how pissed off I am. At over $4000 and 3 tries they can't get it right?
I own a few DJI things but this is the most expensive.
The only thing they offer to me is "Oh well, send it back"
2016-8-22
taborproduction
Donnie Posted at 2016-8-23 02:32
I love  DJI Jamie but I would just  say  to avoid future pain and suffering ASSUME   that they are n ...
This one won't exit ravel mode
2016-8-22
DJI-Jamie
taborproduction Posted at 2016-8-23 04:04
I do see you've created multiple threads on this issue, but have not responded to my initial inquiry. In order to better assist you, additional information would be needed. There can be multiple reasons as to why you are experiencing this issue that can be troubleshooted and resolved. Again, it would ideal to know if you incurred this issue after attempting to update firmware. Could you please elaborate as to what was your process on setting up this particular unit that led you to your current predicament?
2016-8-22
SteadyWTF
Flight distance : 3963865 ft
Donnie Posted at 2016-8-22 14:32
Hey Donnie,
Could you elaborate on what you are talking about with the firmware issues.
I have an Inspire1 drone and a Zenmuse X5 camera.  Until I just read your thread I figured I was supposed to use the Pro Firmware since I fly with the X5.  Could you explain?
2016-8-23
Donnie
SteadyWTF Posted at 2016-8-23 20:28
Hey Donnie,
I have a ...
You are good with the Pro ( which comes with X5 Standard  )  version of firmware .  i just wanted it clear that the X5 Raw has a different version of firmware than the Pro ,  as does the Inspire  1
I guess I did not make this to clear. I did edit my post to help clarify- thanks
Just to re -iterate, you are doing it properly.
donnie
2016-8-24
Krankie
Donnie Posted at 2016-8-24 06:40
You are good with the Pro ( which comes with X5 Standard  )  version of firmware .  i just wanted i ...
Thanks man.  Just trying to figure out why I'm having such a bumpy ride
2016-8-24
Donnie
Krankie Posted at 2016-8-24 20:51
If I can be of any help let me know, I will try.
donnie
2016-8-25
DJI-Jamie
DJI-Jamie Posted at 2016-8-23 05:00
I do see you've created multiple threads on this issue, but have not responded to my initial inqui ...
Do you still need help?
2016-8-30
