AG0N-Gary
Flight distance : 700846 ft
Just to be clear, you are saying you are losing signal at 1000 feet altitude until you reposition antenna (that's normal if the drone is directly overhead). You don't say how far you are horizontally. If you are directly overhead, remember that the radiation pattern from the drone is the same as that of the controller. Maximum signal is to the side of the antennas (located in the legs), and least signal is straight down. Not only does the controller antenna need to look at the drone antenna, but the drone antenna needs to look at the controller antenna for maximum range. You do that by getting it further away from you. Have you tried that? Or do I not understand what I have read? |
