Fly away, crash, and burn.
1299 10 2016-8-30
justbabs
Flight distance : 354081 ft
I launched my new P3P after, about half dozen or so successful flights. It hovered after auto take off, I gave it some altitude (100 ft or so) as I searched for the waypoints mission I wanted to run. That's when I saw my drone come tumbling down to the ground.  My log shows no indication of a battery failure. It also shows my Phantom was rolling over and over as it fell from the sky. Since I did not lose a prop and did not see anything come into contact with my Phantom (It was in a wide open area, so no tree or wire interference), I can only assume the crash was caused by either a motor or ESC failure.
2016-8-30
stevemashon
i just had the same thing happen to mine a few hours ago.  but mine also has burn marks coming out of some of the prop vents
2016-8-30
justbabs
stevemashon Posted at 2016-8-31 08:43
i just had the same thing happen to mine a few hours ago.  but mine also has burn marks coming out o ...
My battery was smoking when I retrieved it.  I'll take a closer look at it.  Props were broken, but all four where still there.  Shell is damaged, landing gear cracked, and camera is gone.  Kinda curious if DJI will cover it under warranty.
2016-8-30
Geebax
justbabs Posted at 2016-8-31 11:10
My battery was smoking when I retrieved it.  I'll take a closer look at it.  Props were broken, bu ...
They may consider it, but only if it was a fault in the aircraft. But it sounds like you don't have a clue what happened.
2016-8-30
Sorry for your crash justbabs. I'd suggest you to sync your flight record in DJI Go app and email support.us@dji.com. Our tech support will guide you to send it in for data analysis and diagnosis.
2016-8-30
kirk2579
Flight distance : 37415 ft
both have same story and both used auto take off....
http://www.phantompilots.com/thr ... ash-and-burn.88491/
2016-8-30
justbabs
kirk2579@aol.co Posted at 2016-8-31 11:29
http://www.phantompilots.com/threads/fly-away-crash-and-burn.88491/
I always use auto take off, and have never had a problem.  I did read there's an issue using it in F mode though.
2016-8-31
greene.thomas-s
Flight distance : 40052 ft
While flying phantom 3 pro at 200' for approximately 6 minutes smoke was observed trailing drone. Attempted to land on residential street as smoke increased. At 83' drone quit and dropped from the air trailing smoke. DJI states no errors noted, must have over heated in hot weather. I sent flight log, photo and weather report. Another tech responded that i must have got water on battery. Clear, dry and temp in 70's. I have photos of burned battery and drone. Battery still smoking when pic was taken. DJI stating battery and damage not under warranty. Anyone else experience battery smoking in flight?
2016-8-31
greene.thomas-s
justbabs Posted at 2016-8-30 21:10
2016-8-31
greene.thomas-s
2016-8-31
kirk2579
justbabs Posted at 2016-8-31 07:31
I always use auto take off, and have never had a problem.  I did read there's an issue using it in ...
have had 3 p3's and never once used auto land or take off.
its way too much fun to actually fly it for me to not....
good luck and have fun flying.
yes I have seen and noticed that auto take off is showing up in a good number of posts lately....
almost like the:
I just calibrated the compass and ......posts
2016-8-31
