Gimbal not stabilized well after crash
wild.images
Flight distance : 4350712 ft
Hi all,
I have some issue with my phantom 3 pro (all worked ok for 40+ flight before)
But I seem that the gimball stabilization is perturbated
I have recalibrated IMU and gimbal but not sure if there is a specific additional gimbal calibration to do
I always fly in follow mode so normally I expect the horizon to kept straight which is not the case here
When I fly straight forward the drone (kept horizontally), when I start the gimball tilt on the right (like overcompensating)
And I stop, the camera tilt on the left (again not needed) and I do not have stabilized image as before
Is there a specific calibration I could do ? Thanks for your help in advance
2016-9-2
shakin
Flight distance : 460039 ft
have a check and see if one of the white rubber dampeners that smooth vibration has come out of its location. happened me before but not after a crash. thats all i can add to this
2016-9-2
Geebax
Unfortunately your clip is too short to get a good idea of the problem. You should be able to do the same thing while holding the drone on the ground and tilting it. Perhaps you could shoot a clip of that being done.
2016-9-2
RedHotPoker
Flight distance : 165105 ft
Have you tried to recalibrate the IMU and gimbal, may as well do the compass too. Haha
RedHotPoker
2016-9-2
DJI-Ken
Flight distance : 1515312 ft
Yes there is a gimbal calibration, from the Gimbal Settings menu you can calibrate the gimbal.
If it still does the same thing than something internally may have need damaged in the crash and you may want to send it in for repair.
2016-9-2
wild.images
shakin Posted at 2016-9-3 00:51
have a check and see if one of the white rubber dampeners that smooth vibration has come out of its  ...
Thanks that was a good idea but after check no problem here. All 4 in good state
2016-9-3
wild.images
Geebax Posted at 2016-9-3 01:01
Unfortunately your clip is too short to get a good idea of the problem. You should be able to do the ...
Excellent idea as indeed more accurate. Thanks for the idea.
I just did a quick video where I move the drone slowly on the floor (front or back) and we can see well that the gimbal is not keeping horizontal and do slowly (very slowly) come back to horizontal
Here is the video link : https://www.dropbox.com/s/l6c9xxl4ostzl60/test-gimbal.mp4?dl=0
I did a recalibration before with no success. Guess this is no other other way to correct and has to go through servicing ?
2016-9-3
wild.images
RedHotPoker Posted at 2016-9-3 02:31
Thanks
Yes I did both + compass (for flight) but no change
2016-9-3
wild.images
DJI-Ken Posted at 2016-9-3 06:50
If it ...
Ok thanks
I just did a quick video as suggested above where I move the drone slowly on the floor (front or back) and we can see well that the gimbal is not keeping horizontal and do slowly (very slowly) come back to horizontal
2016-9-3
DJI-Ken
wild.images Posted at 2016-9-4 04:59
Ok thanks
I just did a quick video as suggested above where I move the drone slowly on the floor  ...
Yes, I'm sorry. Looks like it would need to come in for repair.
2016-9-3
wild.images
DJI-Ken Posted at 2016-9-4 00:44
Ok thanks, I will contact a repair center
2016-9-4
DJI-Ken
wild.images Posted at 2016-9-4 18:27
Sounds good, and sorry about your crash.
2016-9-4
