Video on computer
1146 8 2016-9-5
mbaseytjf
My video is fine when I view it on the go app,but when I use sd  card on my MacBook Pro or Windows lap. It's all glitching the video skips around and jumps....help pleas!
2016-9-5
pdconner
Flight distance : 65407 ft
Sounds like you recorded your video to high.. meaning in 4K or something and your computers cant handle it.. I found this out and I can only record for now in 2K because mine does the same thing on 4K
Thanks
Patrick
2016-9-5
mbaseytjf
pdconner@comcas Posted at 2016-9-6 09:53
Sounds like you recorded your video to high.. meaning in 4K or something and your computers cant han ...
Thanks for input!
2016-9-5
Hello mbaseytjf,did you record a video with high resolution?Could you please change a player to watch the video?
If still no improvement,please upload the video to dropbox,and I'll help to check it.
2016-9-5
mbaseytjf
DJI Mindy Posted at 2016-9-6 03:11
Hello mbaseytjf,did you record a video with high resolution?Could you please change a player to watc ...
seems to be ok on my macbook pro ...i used a diff sd card also
2016-9-8
kirk2579
Flight distance : 37415 ft
copy file to mac or pc
don't play from sd---usb slow
video in app is only 720 low res
if copied to pc hard drive and still stutters --the pc is not up to the job..
reduce resolution or new pc is solution
2016-9-8
interceptorx5
Flight distance : 397 ft
4K needs a powerful computer /video card, especially if you want to edit it.
2016-9-8
pdconner
I had the same issue.. I went out tonight and got the Nvidia GeForce GTX 950 and installed it (Graphics Card) at bestbuy and everything is great now and can watch 4K and record and playback and it is good.. I also have 8 gig of ram already but it is all good now.. might look at updating your video card..
2016-9-8
Aardvark
Flight distance : 384432 ft
I can playback 4k @ 30 fps smoothly (scaled to screen or 4k monitor) using an Intel i5-4300U, 4GB RAM with an on-board graphics chip (Intel HD4400) through displayport to HDMI (1.4 at 30fps (would need to be HDMI 2.0 for 60 fps format)).
Although I edit on a desktop with a bit more power (i7, 6 core @4GHz, GTX480 (no 4k support) and GTX650 (for 4k out @ up to 60 fps), and 24 GB RAM (overkill)).
2016-9-9
