Change file naming system?
1414 5 2016-9-13
caranod
Is there a way to chage how files are named? I would prefer a date code over 001, 002, 003.
2016-9-13
KM5RG-Robert
Flight distance : 2075213 ft
I don't think so, but I agree.
2016-9-13
hummingbird.uav
Flight distance : 27489951 ft
I use a PC plug-in app called "Better File Rename"  It takes a selected list of files and changes the file name in any way you can think of.
2016-9-13
mec234
Also would be nice if the naming convention would continue from one SD to another.... Currently the names start from 001 when a new SD card is used.
So by inserting the date into the name would be a great start, to fixing that issue!
2016-9-15
peter
Flight distance : 545377 ft
The Phantom uses the DCIM standard which does not allow this. The first four characters can be changed by the device make but the four digit serial number is fixed. It's old and historical and based on a FAT16 8.3 filename system, but well understood.
2016-9-15
labroides
Flight distance : 9991457 ft
mec234@gmail.co Posted at 2016-9-15 22:27
Also would be nice if the naming convention would continue from one SD to another.... Currently the  ...
Go to your camera settings (click Menu above the onscreen camera button)
Look for File Index Mode and select the Continuous option rather than Reset and your Phantom will do exactly what you are asking for.
2016-9-15
