DJI OSMO Mobile device error
3533 15 2016-9-23
jeancarlobattad
Flight distance : 47671 ft
Hi there, I purchased my Osmo mobile today from an authorized retailer, charged it up and activated it as the videos and manual said to do. I've mounted my samsung galaxy S7 edge to it and it seemed balanced. If I touch the phone on the right side it goes back to level but when I touch the right side it goes back to level but not all the way. I've played around with the device mounting and found this to be the best set up. The problem begins when I auto calibrate the unit, it says it's calibrated and when I click okay, I get the device mounting error. The motors don't get hot or anything from what I can tell. I'm wondering if it's a mounting issue or my unit is defective. Any help is greatly appreciated and thanks in advance
Just tried it on an iphone 6s and I'm getting the same error
Video here:
2016-9-23
DJI Natalia
Flight distance : 318 ft
Hello sir, may I know can you control it with joystick? and please remove the protective case and try again.
2016-9-24
jeancarlobattad
Hi, yes I can control it with the joystick. I've also tried it more than 10 times re positioning the phone and also removing the case and trying the same with the iphone 6s. Error seems to pop up every time
2016-9-24
apkhou
Flight distance : 3802 ft
even i am getting this error often. no case. i am in the return period - is this a defective device?
2016-9-24
drmaiellaro
When I try motion time lapse I keep getting:
Positioning Error
And the MTL stops before completion.
2016-9-24
DJI-Jamie
Flight distance : 112405 ft
drmaiellaro Posted at 2016-9-25 03:25
Positioning Error
When you balanced the phone onto the gimbal, is the roll adjustment screw tight?
2016-9-24
JCB522
I just tested and when I get that error for motion time lapse the screw is tight. The mobile device error pops up and I can click okay and the phone is still recording while the error pops up and will even finish recording.
2016-9-24
apkhou
any solution to this yet?
2016-9-26
JCB522
None yet, hoping someone finds something out before my return period is over
2016-9-26
DJI-Thor
Flight distance : 13602 ft
Hi, there's a new DJI Go apk in a few days, see if it solve your issue. If not , please contact support.us@dji.com to send it in. Thank you.
2016-9-28
ZCWhukNKIlFB
i have just received my osmo mobile 2 days ago and am getting the positioning error message whenever i do a Motion Timelapse
2016-10-6
jeancarlobattad
Does it complete your timelapse or it just stops recording
2016-10-6
DJI-Thor
ZCWhukNKIlFB Posted at 2016-10-6 22:27
i have just received my osmo mobile 2 days ago and am getting the positioning error message whenever ...
Hi, that is not normal.  What phone are you using? What's the operating system version?   Other than this, does your Osmo Mobile work fine?
2016-10-8
gsciorio
Any luck people? It's been three days for me and I'm not getting the Device Positioning Error too. If I can't figure it out today I'm returning this.
2016-10-8
SemichCSC
Flight distance : 903904 ft
Portugal
DJI-Thor Posted at 2016-10-8 17:17
Hi, that is not normal.  What phone are you using? What's the operating system version?   Other th ...
I have the same issue. S7 Edge Android.
2016-11-20
DJI-Thor
SemichCSC Posted at 2016-11-21 01:39
Hi, you need to send in your unit for exchange.
2016-11-20
