BAD AND LOST SIGNAL FINALY ! HELP !
704 4 2016-10-15
taklingr
Greece
hello and sorry for my bad english. i have a phantom 4 from april. and i have big problem always with signal. on distance about 800 meters and little more, and alltitude about 300 meters the signal is too weak always fianly lost signal and the phantom go home. with my old phantom 3, i never have problem with range. so what happend? i must send my phantom back in service? i am very dissapoiinted with dji.
thank you!
2016-10-15
DJI-Jamie
Flight distance : 112405 ft
Did you happen to notice this after a firmware update or a hard landing? What mobile device are you using? What version of the Go app are you running?
2016-10-15
opendoor499
why would the firmware upgrade restrict distance
2016-10-17
DJI-Ken
Flight distance : 1515312 ft
opendoor499 Posted at 2016-10-18 11:30
Are you flying in an interference free area, please try in a large open field first. If you get the same shot range as before then there could be a issue.
Also, make sure you are pointing the antennas correctly.
2016-10-17
Dacon Productio
I had/have the same problem with video feedback from drone. All problems started after updated the IOS to 10.0.2 and GO app to 3.0.0 and today to 3.0.1.
After 7 batteries of test and trial, I found that if the ANTI-FLICKER is set to AUTO in the camera-settings the video is a lot better. I used to have it set to 60Hz (US) but it causes video problems. Too late now but will try to set it to 50Hz and see how is it.
Will also try the 50Hz in MAIN page, HD, FSP 50Hz.
2016-10-18
