Car charger for Phantom 4
768 7 2016-10-20
damasceno.catar
Tanzania
Hi All,
I've tried the car charger for Phantom4 but it took almost 4h to get the battery fully charger, any ideas of what can I do to improve the time of charging?
Thanks.
Catarina
2016-10-20
DJI Natalia
Flight distance : 318 ft
Hi Catarina, you charged battery and remote at the same time, or only battery? how about the temperature around and input voltage?Please check the following tips:
2016-10-20
damasceno.catar
Tanzania
DJI Natalia Posted at 2016-10-20 11:49
Hi Catarina, you charged battery and remote at the same time, or only battery? how about the tempera ...
Just the battery. Outside temperature was hot but inside the car had the AC on (not sure if it makes it better)
2016-10-20
rodger
Flight distance : 20145135 ft
Most likely that is the case. In the car you are doing DC to DC. You may have better results using anInverter.
2016-10-20
Nigel_
Flight distance : 388642 ft
Car charger takes about 1 hour for me, but only if the engine is running all the time.
If I stop the engine then the voltage drops and then it takes forever.  I'm not sure if it stops charging to save the car battery from complete discharge or if it just charges slowly.
If you did have the engine on all the time then it might be worth checking the voltage on your socket, possibly it is restricted, or maybe it is less if the aircon is turned on and using all the available power.
2016-10-20
ProQuad
Flight distance : 20296870 ft
I too have a car charger, and if the engine is running it does take longer then if you were to plug it into an outlet.  In my case, if the engine is turned off, I think my car stop providing power to the plug-in about about an hour...and yes it does take forever if the engine is not running.
2016-10-20
DJI Natalia
damasceno.catar Posted at 2016-10-20 17:55
Just the battery. Outside temperature was hot but inside the car had the AC on (not sure if it mak ...
OK, please help clarify it is the DJI official car charger, right?
May I know how did you charge it and did you notice any abnormal situation during charging?
2016-10-20
lilsou
Flight distance : 1398376 ft
My guess is your car's cigarette lighter is not up to spec. I have a car that takes forever to charge my phone, but using the same hardware, in my other car it charges twice as fast. Try with another car and see.
2016-10-20
