Phantom 3 Pro binding secondary controller
2515 15 2016-10-28
Heniek W
I am planning to mod one of my controllers , I happen to have 2 of them.., is it possible to have binded 2 controllers to the same craft , so regardless which one I take with me it will automatically connect to P3P ? or is it that each time I will have to rebind the new controller over again and have only one controller as operational  at that moment ?
thanks !
2016-10-28
Hawks100
Flight distance : 134580 ft
I think that you would have to rebind each time you use the other remote.
2016-10-28
Heniek W
Hawks100 Posted at 2016-10-28 13:34
what about controller firmware ? would that be safe to fly on a newer controller firmware than the firmware currently loaded on the P3P ?
or do the firmware have to match on both the p3 and the controller in order to bind the secondary controller ?
2016-10-28
Hawks100
Drone and RC must be the same.
2016-10-28
Heniek W
Hawks100 Posted at 2016-10-28 13:56
can you roll the controller firmware back or reset the controller to the factory default ?
2016-10-28
Hawks100
Why would you want to do that??
Best practice is to be upto date on the firmware on both the drone and RC at all times.
2016-10-28
Heniek W
Hawks100 Posted at 2016-10-28 14:04
Best practice is to be upto date on the firmware on both the drone a ...
I prefer to stay on the firmware where I have no issues with my craft,no limited range problems and no Geofencing ...
2016-10-28
Hawks100
So you have answered your own question then....
2016-10-28
Heniek W
Hawks100 Posted at 2016-10-28 14:52
So you have answered your own question them....
What I replied was that I do not want to upgrade the craft but I would like to bind the secondary controller even if that will be set on a higher firmware version than the craft itself , will that work I do not know, so lets leave the answer to someone that had tried that and can produce an answer based on experience rather than guessing and assumption...
however thanks for your effort !
2016-10-28
Hawks100
I dont answer on gues work pal.
I gave you the answer, but you think you know better.
Good luck with your quest....
2016-10-28
Heniek W
Hawks100 Posted at 2016-10-28 16:15
Good luck with ...
Hey Pal look at your first reply
"I think you would have to...."
You think you know and you know it's a difference,
I appreciate your effort for trying to answer but if you're not sure about the answer sometimes it's better to sit back and wait for someone that knows it for sure based on actual experience.
2016-10-28
Heniek W
Good luck with ...
2016-10-28
Hawks100
Firmware Upgrade Notes
Home / PHANTOM39245 184 2016-04-09 19:13:48
DJI-Paladin
1#
New firmware for Phantom 3 series, Phantom 4 and Inspire 1 has been released at April 7th, 2016. When you upgrade your aircraft and remote controller, please note:
1.       Both aircraft and remote controller must be upgraded to the latest version. If not, “RC Signal Lost” will be displayed on the DJI GO APP.
2.       The upgrade of the aircraft will take about 20 minutes and 10 minutes for the remote controller.
3.       Make sure that the battery level is over 50% before the upgrade.
4.       Do not power off the aircraft during the upgrade process. Following situations can appear : gimbal becomes limp; LED indicators blink irregularly or go off; the aircraft reboot itself, etc. Do not panic it is normal.
5.       Please pay attention to the gimbal status indicator during the upgrade process:
Is this enough proof for you......
2016-10-29
Hawks100
On this note, i think you will find i do Know my stuff on upgrading firmware to the same version as i had a RC replaced under warranty. I had an issue getting them to connect at first, but solved thanks to kind people on here offering help and suggestions on how to fix it.
Next time you want help on here, try to be more receptive to offers of help.
Safe flying with your P3.
2016-10-29
Heniek W
Hawks100 Posted at 2016-10-29 02:17
On this note, i think you will find i do Know my stuff on upgrading firmware to the same version as  ...
thanks Hawks will do,
I connected my secondary controller on unmatched firmware and it works fine with older 1.4 firmware on the bird, so whom ever the guy in Hong Kong Tong Pong is,
he is wrong....
2016-11-1
John Arps
You would have to rebind it with each time you switch remotes otherwise it would not be effective to avoid interference with other controllers and ended up in the crash situation
2019-9-8
