DRONE-flies-YOU
Flight distance : 1638323 ft
According to Tahoe Ed in 1 of these 1000s of threads I've read, ActiveTrack's TERRAIN FOLLOW can track you on varying elevation. It AUTOMATICALLY increases altitude to maintain a constant ABOVE GROUND LEVEL (AGL), but won't go back down if YOU happen to descend. But you can add THROTTLE DOWN and it will decrease altitude, but YOU are doing this, not Mavic doing it autonomously (the descending part).
Someone else already asked a similar question and determined there is not a 100% autonomous way to totally track you DOWN a mountain (and not hit evergreens the whole way down, also).
So, I could see how you set terrain follow to the minimum altitude (which is still too high on all the modes) and just keep the throttle down held down & it'll stay at that minimum altitude up or down ground changes.
