Inspire 1Pro in the mountains
1356 11 2016-11-1
Insieme Agency
Flight distance : 420449 ft
Hungary
Hello Guys,
We will do drone shots in Georgia and the thing is we will be +2000m high.
What do you guys know flying drones in the mountains? I will take my battery HUB, so I can warm my batterys.
Anithing else?
Thanks a lot guys!
2016-11-1
DJI-Jamie
Flight distance : 112405 ft
The Inspire 1 manual says to be careful when flying above 4500m due to altitude density. If you're flying under that, the flight performance shouldn't be affected that much.
2016-11-1
dobmatt
Flight distance : 1831050 ft
Flying at Mt.Everest base camp is different story, but at 2000 m you'll be fine without installing high attitude props.
2016-11-1
RichJ53
Flight distance : 1837356 ft
I fly in the Oregon mountains all the time... I am at 1330 feet base AGL.... No Problems at all
enjoy your Inspire
Rich
2016-11-1
Mike-the-cat
Flight distance : 22488593 ft
Singapore
Agree with Dobbmatt. Have flown at 2100m without problems. It does get windy so take care. Also, at lower temperatures, battery output tends to be lower at the start of the flight so don't fly aggressively.
2016-11-1
filmalaska
Flight distance : 123225 ft
I'm flying in Arizona at 6000' or Alaska at 3500' with no issues whatsoever at either elevation.
2016-11-2
Minmim81
Flight distance : 7780965 ft
I would recommend using the DJI inspire high altitude props are slightly wider in pitch and do make a difference even if they seem not.  slight decrease in flight time.  Very noticeable increase in lift.   they also work fantastic on firmware lower than 1.4 if you use the old x3  due to the way the flight controller needs to stabilise the aircraft it is Less optimal with smaller weight in lower density atmosphere,  unless flying in ATTI (aircraft fw  1.9). Even in normal conditions flying all the time with the X5 it is so much quieter
2016-11-2
dobmatt
Minmim81 Posted at 2016-11-3 14:46
I would recommend using the DJI inspire high altitude props are slightly wider in pitch and do make ...
Just curious, how do you evaluate the increased lift of high altitude props? Bigger payload at sea level? I've been flying this summer in Canadian Rocky Mountains region at 4000-5000' range with these props and - to be honest - didn't noticed any benefits. I assume that the HA props are really effective at Himalayan altitudes where the air is noticeably light and breathing becomes problematic for some people. In my case the system was reporting forced limitation of power supply from battery, particularly during fast passages. And - of course - flying time was reduced by 5 min average. Quieter? Baritone rather than soprano, but equally loud ...
2016-11-2
Insieme Agency
Hungary
Thanks a lot guys for all of your answers!
2016-11-18
DJI-Jamie
Insieme Agency Posted at 2016-11-19 00:39
Best of luck to you!
2016-11-18
Insieme Agency
Hungary
Thanks Jamie, We are at home right now! The video will be out in this week! I will upload the link here!
2016-11-22
DJI-Jamie
Insieme Agency Posted at 2016-11-23 02:29
Thanks Jamie, We are at home right now! The video will be out in this week! I will upload the link ...
Sweet! Looking forward to it.
2016-11-22
