Mike-the-cat
Flight distance : 22488593 ft
Singapore
I have synched several times on the same device (call this Device A) where I spotted the problem.
1). If you don't do anything, you won't notice a problem. The summary display looks fine. However, when you tap on some recent flights, the screen changes to a 'No GPS' screen and when you get out of that screen, the record on the summary screen is changed.
2) When the latter occurs, the flight distance is set to the flight distance of the first 'failed' record and the flight time is set to zero. This is cloned across all the mutated records that one clicks on and subsequently corrupts.
3) Upon synching with another device (call this Device B) that originally did NOT have this problem, and then back to Device A, some of the records are restored but other errors cropped up. After two rounds of re-sycnhing, about 10 flights have disappeared from the 'summary screen'.
I have not tried to delete the program and re-install as that will entail a loss of some of the video proxy files. I know how to take those off and put them back in but that takes time and trouble. Maybe later. Meanwhile, as other people are noticing this bug, I suggest you get the engineers to work on the problem. |
