Very poor framerate in simulator: DJI Go 3.0.1
1247 6 2016-11-10
Rotareneg
Flight distance : 676634 ft
I loaded up the simulator for my P3S in DJI Go 3.0.1 on my Nexus 7 (2013) and the frame rate is very poor, like 5 frames per second or so. It used to run nice and smooth back on version 2.8.? but I hadn't used it for a while so I'm not sure if the problem started in 2.9 or 3.
2016-11-10
DJI Natalia
Flight distance : 318 ft
Have you tried different android devices with V3.0.1 APP? I have tested on my phone, there is no issue about the frame rate.
Please try to delete the APP, re-install it and check again, if still the same case, you could upload a short video for further evaluation.
2016-11-10
fanscd256e3f
Flight distance : 175495 ft
I have a Galaxy S7 and the video works fine 4 gig of RAM 2.5ghz quad-core 64-bit. Yours has 2 gig of RAM 1.5 GHz processor and 32 bit
2016-11-11
Rotareneg
I do not have another device to test it on. Uninstalling and reinstalling 3.0.1 had no effect. Here is a video showing the simulator in 2.8.4 and 3.0.1 (I apologize for the terrible quality, I don't have another better device to record video) :
In 2.8.4 everything runs fine, but in 3.0.1 the frame rate is very low, even the low battery warning on the top runs choppy.
2016-11-11
DJI-Jamie
Flight distance : 112405 ft
Rotareneg Posted at 2016-11-12 01:12
I do not have another device to test it on. Uninstalling and reinstalling 3.0.1 had no effect. Here  ...
Just to clarify, do you have USB debugging enabled or disabled?
2016-11-11
Rotareneg
This is with a P3 Standard, there's no USB connection, just wifi.
2016-11-11
Rotareneg
Same problem with the just released DJI Go 3.1.0
2016-11-14
