I already looked for solutions, I asked for help to Support. I did what they told me but I still have the same problem. Now attached photos and video of how it works. The problem started when the Remote Control was upgraded to 1.8 video transmission malfunctioning. I use a Samsung S5, I always used it there and it worked perfectly ... It was updated when I was connected to WIFI ...
I want to make it clear that in case I have an accident for this reason, I have all the conversations stored here to use constancy and proof that I have not had a gratifying solution to date ... I need SOLUTIONS ....Someone have the same problem? Do you find a solution? I don´t want to back in firmware because this will cause an other problem for sure...
I'm having problems with video feed also 3 to 4 second lag after the 1.8 RC update and video dropping constantly same here working great before update Samsung S5 tab 2S
This problem exists since two weeks now. Somewhat disappointing that DJI did not fix it meanwhile. I downgraded to 1.6 and would give a v1.9 or similar a try as soon as it gets out...
Could you please enter the image transmission settings then check if there's interference around?
Also please ensure that you do not have any programs running in the background.
Yes, I have the phantom 4 and I have had the same problems and actually crashed my drone due to the image transmission going out. I have always flown my drone and never crashed or had any problems. My first flight after downloading firmware 1.8.0, I crashed the drone. Image transmission was horrible. DO NOT FLY DRONE ON 1.8.0!!!! Now i'm having to shell out 600$ worth of damages.
It's almost funny how DJI is in denial about this. The forums and Facebook groups are full of people having this problem and it has been tested many times that a RC downgrade to 1.6 helps on the issue. Would be great if DJI just fixed it instead of writing about interference etc.
I flew with 2.9.1 this weekend and it didn't help. The video signal went from full bars to no signal within seconds when less than 1 mile out. Haven't tried 3.1.2 yet that will be next up.
Irekim Posted at 2017-1-23 18:17
I have a p3pro and a p3adv. somehow my p3 adv remote thinks its a p3 pro remote. Is there a way to reset or fix this error im sure I made?
Any helps appreciated.
wish I could but as far as I know the adv and pro remote are same
