64gb or 128gb card for P4P?
6084 22 2016-11-18
trance728-
Flight distance : 298048 ft
I've been told in the past that getting higher capacity cards leave you with the chance of losing more footage should the card crap out. Obviously that still makes sense, but with the P4P capable of 100mbps then it's going to eat up more memory. Is it wise to get 2x64gb cards or go with the bigger 128gb one. On the basis that they would cost the same,what would you do?
2016-11-18
Labroides
Flight distance : 9991457 ft
No ... it's not going to need more storage because it's not making bigger files.
And even if it was, you'd still be able to store many flights on the card sizes you mention.
If you value your images, it makes a lot more sense to use a number of 16GB cards and swap them out every flight rather than risking a lot of work sending it out again and again.
Bigger is not always better.
2016-11-18
marctronixx
Flight distance : 210118 ft
DO DJI list a set of recommended brands and card speeds for the p4/p4pro?
and since i am new to p4pro, is it microsd or standard size sd?
2016-11-18
Labroides
marctronixx Posted at 2016-11-19 12:18
and since i am new to p4 ...
Here's what DJI have to say:
Supported SD Cards        Micro SD, Max Capacity: 128GB.
Write speed ≥15MB/s, class 10 or UHS-1 rating required
2016-11-18
fans8fa681d7
Flight distance : 3505518 ft
Labroides Posted at 2016-11-18 16:23
And even if it was, ...
Obviously you don't shoot a lot. I've had 5 drone and never lost one or a memory card, but i have filled them up. The h265 ARE larger files.
2016-11-18
Labroides
fans8fa681d7 Posted at 2016-11-19 12:53
Obviously you don't shoot a lot. I've had 5 drone and never lost one or a memory card, but i have  ...
Obviously you don't value your images and you have no idea how much I shoot.
Perhaps you just fly around your front yard or your local park.
But in the places I fly, there's no way I'd send my images out again after I bring them in safely.
Keeping a week's work on one card is crazy.
2016-11-18
RedHotPoker
Flight distance : 165105 ft
I find 64gb is a great size for 4K video. YMMV
RedHotPoker
2016-11-18
DJI-Jamie
Flight distance : 112405 ft
Write speed does make a big difference.
2016-11-18
Labroides
DJI-Jamie Posted at 2016-11-19 15:27
As long as your SD card meets DJI specs, what difference does the SD card's write speed make?
2016-11-18
DJI-Jamie
Labroides Posted at 2016-11-19 13:46
It helps improve the quality of the overall playback with high end resolutions like 4K.
2016-11-18
Labroides
DJI-Jamie Posted at 2016-11-19 16:47
Huh?   The WRITE speed helps wi\th playback?
That sounds unlikely.
But no-one plays back from their SD card anyway, they copy the file to a hard drive.
As long as your card meets DJI specs, it will be just fine.
Paying more for a "better" or faster card makes no difference.
The speed bottleneck is in the Phantom, not the card being written to.
2016-11-18
fans8fa681d7
Tip: The post by the administrator or moderators shield
2016-11-19
Labroides
fans8fa681d7 Posted at 2016-11-20 02:31
Lol... I'm just good with my drones. I've flown in 20 countries never lost a memory card. STFU you ...
Since you're so good with your drones, no-one else will ever lose theirs.
In that case ignore my advice because I'm such a "noob".
"Only an amateur would be worried about sending up a drone and not getting back."
Quite the opposite.
When you know the value of your work, you take more care to protect it.
What an absolute tosser.
2016-11-19
fans8fa681d7
Labroides Posted at 2016-11-18 19:10
Perhaps you just fly a ...
Lol... I'm just good with my drones. I've flown in 20 countries never lost a memory card. Come on you noob. My point is that for some people who shoot 5-6 batteries a session shoot quite a bit of video and it would be handy to not have to switch memory cards, one less micro thing to worry about. Only an amateur would be worried about sending up a drone and not getting back.
2016-11-20
fans8fa681d7
fans8fa681d7 Posted at 2016-11-20 06:50
Obviously you don't value your images and you have no idea ho ...
DJI FORUM don't delete posts you have no business deleting
2016-11-20
trance728-
fans8fa681d7 Posted at 2016-11-20 09:51
What post did they delete?
2016-11-20
Labroides
"The h265 ARE larger files."
Really?
You need to check your information before making out like you're some kind of expert.
Surprise surprise, the facts don't back you up at all hotshot.
http://www.videoconverterfactory.com/tips/h265vsh264.html
2016-11-20
MNL5099
Flight distance : 820174 ft
FYI, if plan to record 4K at 100Mb/s on the P4P, you will need a U3 rated micro SD card, otherwise you won't be recording at 100Mb/s. At 100Mb/s a 64 GB SD card will hold 85 minutes of video.
I currently have a P3P and I use two 64GB micro SD's with a U1 rating. This way I have redundancy and I can be using one card in my phantom while using the other with my computer. Also, buying two 64GB is cheaper than one 128GB card.
I put a little guide together for myself. All the information you need to know about SD cards and data rates with the phantom series aircraft can be found below.
____________________________________________________________________________
                                  Transfer Speed Information
1. P3P Max write speed is 60 Mbps (7.5 MBps) at Cinema4K (.45 GB per minute, or 27 GB per hour)
2. P4P Max write speed is 100 Mbps (12.5 MBps) at Cinema4K (.75 GB per minute or 45GB per hour)
3. Lexar 64GB Micro SD max write speed is 160 Mbps (20 MBps) & 95MBps Read
4. Mbps (Mega Bits per second transfer speed)
5. MBps (Mega Bytes per second transfer speed)
6. Conversion 8 bits = 1 byte ———So, 8 Mbps = 1 MBps
7. Minimum sustained write speeds. A speed class rating means that the card has been verified to never write slower than the speed of that class
    1. U3: Minimum 30 MB/s Write
    2. U1: Minimum 10 MB/s Write
    3. Class 10: Minimum 10 MB/s Write
    4. Class 6: Minimum 6 MB/s Write
    5. Class 4: Minimum 4 MB/s Write
    6. V6: Minimum 6 MB/s Write
    7. V10: Minimum 10 MB/s Write
    8. V30: Minimum 30 MB/s Write
    9. V90: Minimum 90 MB/s Write
8. Online Guide https://www.bhphotovideo.com/exp ... cards-money-can-buy
9. Note, a U3 rated SD card is needed for the P4P. https://www.amazon.com/Lexar-Pro ... ds=u3+micro+sd+card
I hope this answers your questions!
2016-12-9
Labroides
MNL5099 Posted at 2016-12-10 08:05
The P4P has a max video bitrate of 100 Mbps (12.5 MB/s).
And it records perfectly on a U1 rated card.
If you needed U3 cards, DJI would state that in the specs and provide cards of that rating.
2016-12-9
FlyLowandSlow
The Lexar Pro 64gb cards that meet the specs for the P4P do not work with the P4P
2016-12-9
Labroides
FlyLowandSlow Posted at 2016-12-10 10:11
And the Lexar 16GB cards that came with Phantom 3 work just fine in the P4pro.
2016-12-9
FlyLowandSlow
Labroides Posted at 2016-12-9 15:31
The 32 works fine as well, but there is a firmware issue with the P4P and the 64 gb lexar pro
2016-12-10
ricardo paula
Brazil
I right sure with you. My 128 48MBS stops to records all time.And my 53 GB 80MBs not.
2017-5-20
