Lightbridge and GoPro4
1791 7 2015-2-10
mtahat
Jordan
Hi,
I used the lightbridge with the GoPro 4 via the HDMI cable, and everything had gone fine until I suddenly lost the connection while flying, and the Phantom 2 returned home. Now I have a solid red light when connecting the HDMI cable with the GoPro 4. I connected another camera via the AV signal, at it transmitted correctly.
Do anybody know what has gone wrong?
Regards,
2015-2-10
DJI-Jackson
Flight distance : 51243 ft
Hi,mtahat.
Please make sure GoPro 4 should be set as following picture . And if it was set and no videos either , please change another HDMI cable.
screenshot
screenshot
2015-2-11
mtahat
Jordan
DJI-Jackson Posted at 2015-2-11 18:26
Hi,mtahat.
Please make sure GoPro 4 should be set as following picture . And if it was set and no vi ...
Thanks,
I tried different formats but nothing works, I will try another HDMI cable and let you know what happen.
2015-2-11
mtahat
Jordan
Hi,mtahat.
Thanks,
2015-2-11
ianwood
Flight distance : 5236 ft
Try the new Hero 4 firmware. It should fix output problems for Lightbridge.
2015-2-11
mtahat
Jordan
ianwood Posted at 2015-2-12 13:07
I did update it, but unfortunately it did not work.
2015-2-12
Niki
Russia
Hello. I have the same problem. The video was gone after the third flight. Tried to upgrade dji lb, but not helped..
2015-2-22
ianwood
If both Lightbridge and Hero are up to date you should be getting 480p out of the Hero in the higher resolution modes which will work on the Lightbridge. What still is not working is the OSD output in 480p over HDMI which DJI is looking into and will hopefully fix soon.
2015-2-25
