Dead joystick
1085 16 2016-12-11
Migue_alex74
Has anyone experienced this?
Went for a flight today, when I powered up got the notification for a new firmware, ran the update and flew fine through 2 batteries with a connected the iphone through the USB-A and still everything fine, on the third battery I switched to the mini usb -ligthning connector and when powered the rc on I got an error with a continuous beeping, I went into the rc calibration within the app and the right stick is not responsive, calibration times out and fails
2016-12-11
Migue_alex74
My app version is 3.1.1, aircraft and RC version is 01.03.0000
Aircraft SN 08QDDBC01200V4, RC S/N is 08RDDB500104BK
Went to DII Assitant 2 and tried a factory reset for the rc, gave me a failed error
Tried refresh on the firmware, failed
Tried to downgrade but also failed
2016-12-12
Hi Migue, what's the error when you turned on the RC?
2016-12-12
Migue_alex74
DJI Mindy Posted at 2016-12-12 16:39
stick err and then re-ctr stck
2016-12-12
Migue_alex74
When I connect to DJI Assistant 2 I see listed the v01.03.0000 listed twice, one with date 2016-12-06 and one with 2016-12-09
2016-12-12
Migue_alex74 Posted at 2016-12-12 16:45
Please try to move the sticks, gimbal dial and camera settings dial after turn on the RC.
2016-12-12
Migue_alex74
DJI Mindy Posted at 2016-12-12 16:57
All other dials and stick operate
2016-12-12
Migue_alex74 Posted at 2016-12-12 17:05
Please try again, move the dials and stick for several times.If still no work, please let me know.
2016-12-12
Migue_alex74
DJI Mindy Posted at 2016-12-12 02:34
Tried multiple times, no change
2016-12-12
Migue_alex74 Posted at 2016-12-13 01:24
The error message "Stick err + re-ctr stck" means control stick is not centered.
It's probably a hardware issue, since you had re-centered the stick and calibrated the RC.
I'd suggest you to send it in for further evaluation.
Please send an e-mail to support@dji.com with the following info, the subject should be " Forum support" . We'll help you create a case.
Case illustration:
Country:
Full name:
Email address:
Phone number:
Shipping Address:
Zip Code:
Forum link for your case:
2016-12-12
Migue_alex74
DJI Mindy Posted at 2016-12-12 19:44
Hi Mindy: Thank you for your follow-up. I already had a support case no. CAS-359801-M4X9Z7 but will send the email and the link to the thread.
Miguel
2016-12-13
Migue_alex74
2016-12-13
DJI-Ken
Flight distance : 1515312 ft
Migue_alex74 Posted at 2016-12-13 11:27
Miguel
One more thing to try, probably won't make a difference but it doesn't hurt to try. I see you are not using the DJI GO 4.0 app.
Can you install the new GO 4.0 app and try a stick calibration.
2016-12-13
Migue_alex74
DJI-Ken Posted at 2016-12-13 10:19
Hi Ken: I did try the DJIGo4 that afternoon but same result. RC is on the way for service.
2016-12-13
DJI-Ken
Migue_alex74 Posted at 2016-12-13 14:23
Ok thanks.
Sorry about that.
2016-12-13
Migue_alex74 Posted at 2016-12-14 01:27
Miguel
If you already had a case, then you don't need to send email again. Thanks.
2016-12-13
DJI Natalia
Flight distance : 318 ft
Our support received your e-mail asking for the around time.
Generally speaking, it will take around 2 weeks, please feel free to let us know for any questions, thanks.
2016-12-15
