Phantom 4 Pro Camera Live View Problem
8738 16 2016-12-20
fans4f59b9a9
Malaysia
Same as title, everything works nicely.
GPS signal, remote controller, apps, but the live view from camera doesn't show at all.
I have updated all the firmware including the drone and the remote controller, but I still not able to receive any live view from my Phantom 4 Pro.
I am using iOS newest app DJI Go 4 and an iPad Air.
Please help if got any solutions, thanks.
2016-12-20
fans4f59b9a9
Malaysia
One more : My S7 edge worked properly on Camera Live View.
2016-12-20
Svt04cobra
Mine is working fine with an Ipad Air 2.
2016-12-20
Indio
Flight distance : 303373 ft
Austria
if you have the HDMI modul installed - look at the settings !
2016-12-20
Have you tried to change another original lightning cable to connect your iPad to RC? Could you please provide a screenshot of the transmission?
2016-12-21
Nigelbrinkmann
Flight distance : 586391 ft
Don't forget this is a 3 year old iPad I think they were released in November 2013 it may not have enough processing power, Its got the old m7 processor in it, this device has recently been replaced by the 9.7 inch iPad Pro. So as you say that your s7 edge works well, so that telling me that your iPad device is not powerful enough, or cable issue as dji Mindy stated.
2016-12-21
fanse186c04e
Flight distance : 26170253 ft
shut off the geo reference and your problem is gone!, i had it to.
2016-12-21
fans468f5846
fanse186c04e Posted at 2016-12-21 10:28
I am having the same issue, can you explain where I find the 'geo reference?'
2016-12-24
fanse186c04e
fans468f5846 Posted at 2016-12-24 18:25
In the menu somewhere
2017-1-16
fans56c57b8e
HELP!!! My Camera Live View goes in and out all of the time. I'm using the iPad mini 3 iOS 10.3.2, new cord.
2017-5-31
fans56c57b8e
DJI Mindy Posted at 2016-12-21 03:03
Hi Mindy, HELP! My Live View goes in and out all of the time. the screen turns black sometimes and green other times. Updated Firmware, iPad mini 3, iOS 10.3.2. tried a new cord. Suggestions?
2017-5-31
theGrindLab.com
Flight distance : 1375846 ft
fans56c57b8e Posted at 2017-5-31 02:39
If you have access to a Mini 4, try that. The Mini 3 is much less powerful than the Mini 4, and is likely not powerful enough to use with the P4P and DJI Go 4.
2017-5-31
Tampa Steve
theGrindLab.com Posted at 2017-5-31 03:00
Thanks for your suggestion. I don't have access to the iPad mini 4... unless I purchase one. (I'd purchase the min i4  if I knew "for sure" that it would work).   What about my iPhone 6+? I have the same problems on it as well.
2017-5-31
AlexFR
Is somebody can tell me if it's possible to zoom and how with camera of the Phantom 4 pro plus? Thnaks in advance. :-)
2017-5-31
theGrindLab.com
Tampa Steve Posted at 2017-5-31 09:56
The 6+ should not give you trouble, based on what other users have said in the forums. I only have experience with the Mini 3, Mini 4, and various Android devices,  and I can tell you the Mini 4 experience is far better than the Mini 3. It's virtually error free.
2017-5-31
DJI-Jamie
Flight distance : 112405 ft
Try the 6S+ and see if the feed improves. If you've already tried different lightning cables, try toggling the hardware decoding option to see if that helps as well. You would also want to check your antenna configuration as well to ensure you're getting the best signal while in flight:
If the issue persists, can you verify which Go app version you're running?
2017-5-31
DJI-Jamie
AlexFR Posted at 2017-5-31 10:38
It does not have a digital zoom option.
2017-5-31
