P3S Error will not fly or do anything
1724 14 2016-12-21
MasterPete
Hi i have a problem with my new phantom 3 standard. Just bought it brand new yesterday and i still havent been able to fly it.
Problem is when i got the drone i did everything needed (did the update also) problem now is every 2 secconds theres a loop of two beeps and the rear lights of the drone flashes green, red then yellow.
And with these problems the controller is also giving me problems too.
Error comes up on the top middle of the screen and says main controller dator error.
When i click on that it says "Barometer Error"
I have tried restarting the drone time after time and still nothing.
Not my video but the same thing is happening.
2016-12-21
BillW50
The only thing I can think of is doing a IMU calibration. There are videos that show how to do it. And unless someone else comes up with another plan, my next step would be to take it back for replacement or refund. Something is definitely wrong.
2016-12-21
MasterPete
BillW50 Posted at 2016-12-21 22:16
I take it its not an error much people know of.
2016-12-21
DJI Natalia
Flight distance : 318 ft
As you can see in the manual, the led status means" Turning on and running self-diagnostic test", which is normal.
Before upgrading the firmware, any error message pop up on the screen?
Would you please make a screenshot of that error?
2016-12-21
MerlinL14
Flight distance : 2858 ft
It's not his video Natalia, he used it as a reference to what is happening to his P3S.
2016-12-21
MasterPete
DJI Natalia Posted at 2016-12-21 22:30
According to the video, there is a gap between the shells, may I know what happened?
Would you please make a screenshot about the error?
No error at all. I turned on the drone and all was fine till i updated it and now all it does is flash the lights, do beeps and gives error messages. How long does it take for the self-diagnostic because i left the drone on for close to an hour and still does the same thing.
2016-12-21
BillW50
No it doesn't take an hour for sure. Self test and warming could take like 5 minutes altogether if the weather is very cold. Did it finish the update ok? I mean did it say update complete?
2016-12-21
DJI Natalia
MasterPete Posted at 2016-12-21 19:35
Thanks for the information, may I know what device you're used to upgrade the firmware? it said"Successfully" on the screen?
Would you please format the SD card, delete the app, re-install it, then connect them properly, and check whether you can get it upgraded again?
2016-12-21
MasterPete
Hi. I used a S7 edge and it did say successfully updated on my phone. Ill try another phone when i get home and i will update after.
2016-12-21
MasterPete
Same thing as before.
2016-12-21
DJI Natalia
Sorry to hear about that, if the error persists after upgrading again and calibrating IMU, then it needs to be sent in for further evaluation.
Please send an e-mail to support@dji.com and our tech support will help you create a case and guide you to send it in.
2016-12-22
MasterPete
DJI Natalia Posted at 2016-12-23 17:02
Please send an e-mail to  and our tech support will help you create a case and guide you to send it in.
Its all good now i returned it yesterday and got another one. Went for my first flight today and love it.
2016-12-23
DJI Natalia
MasterPete Posted at 2016-12-23 17:47
Glad to hear about that, enjoy the flight.
Merry Christmas!
2016-12-23
fansbc434456
Denmark
do an imu calibration
2016-12-25
CHEOLK
Flight distance : 5299 ft
Singapore
Mine was like this also.  After  upgrading the rc won't start.  After few days it suddenly start,  like it went into hibernation and then woke up.
2016-12-25
