Can't change shutter speed from the remote
753 5 2016-12-21
FotoSander
Flight distance : 416900 ft
Sweden
I'm used to being able to change the shutter speed with the remote controller when using P3P but on P4P I can't seem to do that. Would be useful when taking still photos and the light conditions change often.
2016-12-21
Hello FotoSander, you can change the shutter speed when in S mode and M mode.
2016-12-21
Labroides
Flight distance : 9991457 ft
Practise with the thumbwheel a bit.
You click it to change the field you want to select.
When the shutter speed is highlighted in blue, turn the thumbwheel to change the setting.
2016-12-21
FotoSander
Sweden
DJI Mindy Posted at 2016-12-22 03:38
Please refer to the screenshot.[view_image]
I did try that but it didn't work. Maybe because I can't get the shutter speed box to highlight in blue as Labroides suggested.
2016-12-21
Labroides
FotoSander Posted at 2016-12-22 14:10
Just push in on the thumbwheel ... click, click, click and it will cycle through the fields turning each one blue in turn.
ps .. it appears that you have your camera set to underexpose and your pictures will be too dark with EV-1.7.
Something else to adjust when you work out how to use the thumbwheel
2016-12-21
FotoSander
Sweden
Labroides Posted at 2016-12-22 04:47
Oh, thank you! Had missed that you could do that.
2016-12-21
