Return to home climbing in height
1129 4 2016-12-24
Rjroxie
I did my first long range flight the other day and when I got to 3.1 miles out I hit the RTH button and it started home and by the time it was back home it was at 958 feet high?? That bothers me because I have my max height set just below 400 feet. Has anyone else had a similar problem like this?
Thank you
2016-12-24
f3honda4me
Known bug. It happens if you are above your RTH preset height when you initiate RTH. Should be fixed in a future update.  Just set an RTH height higher than you are going to fly at.
2016-12-24
Rjroxie
Good to know, I have tested the RTH several times in the yard and it works flawlessly and it was about half way home before it climbed to the 900 + feet, I was just wondering if it had something to do with the big ravine that it was flying over, thought that it may have been reading the overall height of the drone as it was passing the deepest spot but when it got back it was sure enough way up there.
Thank you.
2016-12-24
DJI Natalia
Flight distance : 318 ft
We'll fix it with the next firmware version for the long distance RTH issue.
Sorry for the inconvenience caused.
2016-12-25
fans82f30c9f
Flight distance : 80112 ft
soon I hope Natalia and the few other bugs as well. Thanks for your support here.   donnie
2016-12-25
