Gimbal always need calibrating every battery
1433 11 2016-12-27
marksy
Flight distance : 42792 ft
I dont know what you nuffys are doing at DJI,
But so far, my experience with the P4P is bad.
Your app is fracking dumb, and now everytime I turn the battery off, I need to re-calibrate the gimbal, although I`m spending more battery volts trying to get yourmfracking app to work first, so I end up have 60% before I even take off, your bloody smart choice to choose "HERE" maps... Maps arent helpful if they are years out of date, and a big fracking blur.
Get your act together. Get some fixes happening, otherwise I`m expecting a refund.
2016-12-27
Geebax
Are you looking for an answer to your problems or a fight?
2016-12-27
RedHotPoker
Flight distance : 165105 ft
Sounds like we have another drone misbehaving? ;-)
Where did you acquire this Phantom?  Perhaps you shall return it for a proper working replacement model.
Sorry, if we can't help you fix it online, then you'll need to replace it, or send it in for repair. ;-)
Good luck..
RedHotPoker
2016-12-27
DJI Natalia
Flight distance : 318 ft
Marksy, sorry that you are experiencing difficulties, we'd love to help you.
Would you please help confirm AC firmware? when turning off the battery and turn it back on, any notice on the APP?
What mobile device you are using? please describe it in detail for the map issue.
It's much appreciated if you could upload a small or some screenshots showing the situation you mentioned for evaluation, thanks in advance!
2016-12-27
marksy
DJI Natalia Posted at 2016-12-28 15:12
The same map problem that everyone has commented on in the playstore. There are more 1 star comments than 5. I`d start looking there first, that's a free tip.
When the app finally connects, it works, besides the maps being blurry. But its painful trying to get app to work, and now I need to calibrate the gimbal every battery.
2016-12-27
DJI Natalia
marksy Posted at 2016-12-28 14:45
For the here map case, we've reported to our engineers.
Each time you turn off the battery and turn it on, the aircraft will run self-calibration, and then you need do the calibration via APP, right?
If you do not calibrate it manually, what is the error on the APP? or would you please make a small video for us?
2016-12-28
marksy
DJI Natalia Posted at 2016-12-28 19:27
There is no error that pops up in the app, the gimbal is just not level horizontally.
2016-12-28
Ange1walk
Flight distance : 30305 ft
Austria
marksy Posted at 2016-12-28 22:08
Hold C2 + Turn Cam Settings Wheel in either direction to correct Horizontal roll.
2016-12-28
Punchbuggy
Flight distance : 483166 ft
Ange1walk Posted at 2016-12-29 08:52
Yep, that's how to resolve the angle in the field, for sure. With regard to set-up Marksy, is it safe to assume that when you used GO to perform the gimbal calibration that you were on a flat surface? You can use your phone compass to check first.
2016-12-28
marksy
Punchbuggy Posted at 2016-12-29 11:30
The first time yes, but its hard to find a flat surface in the bush. Lol. I`ll try the c2 trick. Thanks.
2016-12-28
DJI-Jamie
Flight distance : 112405 ft
marksy Posted at 2016-12-29 12:50
Please keep us posted if the issue persists.
2016-12-28
marksy
Updated new firmware, issue persists.
Getting pretty annoying now.
Whats the fix?
2017-1-19
