Loss of Mavic Pro due to loss of signals
4553 23 2016-12-28
fansc06d2ab3
I lost my Mavic Pro yesterday in open sea while the drone was approaching a golf course. On its way to golf course, there was a sudden loss of signal and RTH function couldn't bring my drone back to me after all. Look for the drone at the last contact point but nowhere to be found. I have attached flight log and the video of its last moment for reference.
Still can't understand why the RTH has failed to function properly.
My experience with Mavic Pro is disappointing considering I had to bring it to service a dead pixel in the camera when I laid my hand back in November.
Flight log
Flight log
2016-12-28
Incredible Aeri
What operating system were you using?
2016-12-28
fansc06d2ab3
Android 6.0
2016-12-28
Incredible Aeri
I think this may have to do with Android. Do we have a poll on who has lost their drone and what operating system they were using?
2016-12-28
c_future
Austria
we had the same issue with a phantom 3  -- looking at the sensor - flight logs - it was because of faulty compass values (180° in 0,2 seconds) on open sea, no obstacles. since phantom 4 there are 2 built in for that reason.
so please raise a support case, provide the flight logs and keep us updated.
also & out of interest, you can post the flight log link to healthy drones here.  next week i will fly my mavic first time over open water a lot.. so far I had 0 issues with my setup, hope it will stay as it is.
2016-12-28
fansc06d2ab3
May i know how to post the flight log link here?
2016-12-28
c_future
Austria
go to https://healthydrones.com/  and upload your (1-2 mb size) flighlog .txt file which you can extrat from the local dji folder of your smartphone.
the web browser url of your flight data on healty drones is persistent - just copy paste it here.
2016-12-28
MavicUser
Flight distance : 431417 ft
What was the distance between you and the Mavic when you lost contact?  From the map you posted, it looks like you launched from a boat?  What firmware version is on the Mavic?  What DJI Go version were you using?
2016-12-28
trance728-
Flight distance : 298048 ft
Incredible Aeri Posted at 2016-12-28 07:50
RTH is a built in function of the ac as well as the rc, I can't see any way that you could blame that on the OS of the phone.
2016-12-28
trance728-
MavicUser Posted at 2016-12-28 08:24
If he did launch from a boat I wonder if the Mavic lost connection with the RC and RTH initiated and flew it back to the home point which would just be water.
2016-12-28
DJI-Ken
Flight distance : 1515312 ft
Sorry for your loss, contact support and they can evaluate your flight record from your DJI account.
Also sync your flight records.Did you record the homepoint before taking off ?
Did you take of from land ?
Was the RTH set to RTH, hover, or land ?
Did you get any warning messages during the flight ?
What is your email and I will look at your flight record to see if I see anything that could have caused it.
2016-12-28
fansc06d2ab3
DJI-Ken Posted at 2016-12-28 23:35
Hi Ken, this is Matt.  My email is mccheung8@yahoo.com. Thanks.
2016-12-28
fansc06d2ab3
c_future Posted at 2016-12-28 22:09
My healthy drone log:
https://healthydrones.com/main?f ... amp;page_id=SENSORS
2016-12-28
c_future
Austria
https://healthydrones.com/main?f ... ENERALNotifications
..interesting is the constant changes of mode to wifi for example which anyhow cant work at a distance of 3,488 ft  / 1 kilometer
and all that happended seconds before your mavic disappeared.maybe the (physical) switch was not perfectly set?
when I had my connection loss and RTH scenario  - or on any other flights -- never saw wifi mode flapping in the flight log
2016-12-29
DJI-Ken
I reviewed your flight, I saw that you went around the cliff and your altitude (45m) and it looks like the aircraft may have crashed into the cliff.
You had a weak signal and I see you let off the forward movement but it kept going after that for a bit. It was slowing down but it looks like it hit the cliff before it could stop.
The flight data analysis department will have to evaluate to see what exactly happened.
2016-12-29
fansc06d2ab3
I sent an inquiry to support and hopefully they will also send me a reply.
2016-12-29
fansf0572733
Flight distance : 2098566 ft
You lost signal. As a result, RTH was initiated. However, it crashed on its way back due to the RTH altitude was not set high enough.
2016-12-29
Kevin16
Flight distance : 353642 ft
DJI-Ken Posted at 2016-12-29 08:13
Interesting.  Couldn't have been in Cinematic mode?  That takes a bit longer to stop.
2016-12-29
DJI-Ken
fansf0572733 Posted at 2016-12-29 17:01
That's not what happened, the aircraft did not lose signal.
When the OP got the Weak Signal message, they left off the full forward stick and the aircraft was slowing to a stop and looks like it ran into the cliff.
Full aft stick input should have been given.
2016-12-29
fansc06d2ab3
DJI-Ken Posted at 2016-12-29 20:43
From the last moment of the video, it was still up in the air and have clearance above the cliff. Besides there's supposed to be obstacle avoidance on the front, that means the function is not working?
I look at the healthy drone log, there's been constant switching to atti mode at the last moment, perhaps that switch off the obstacle avoidance?
2016-12-30
DJI-Ken
fansc06d2ab3 Posted at 2016-12-30 17:09
Again, the flight data analysis team will have to review and determine the cause.
You've already contacted support right and started a case?
2016-12-30
fansc06d2ab3
DJI-Ken Posted at 2016-12-30 22:19
Yes, but they have not got back to me yet.
2016-12-31
DJI-Ken
fansc06d2ab3 Posted at 2016-12-31 00:04
it will take some time, let's see what happens by mid week.
2016-12-31
fansb40d1cae
You never stated your launch location, sea (boat) or land. I'm sure slot of readers are curios
2017-4-25
