GS Pro?
1143 3 2017-1-4
bsett
So if I decide to use the new GS Pro for flying both my P3S and P4 pro does that mean I can remove both the DJI Go and DJI Go 4 apps from my iPad? Also should I remove them before installing new GS Pro app or is there something I need to do in regards to syncing data first?
2017-1-4
WYHSniper1007
Flight distance : 1003822 ft
You don't need to remove the other app.
2017-1-4
Mallettron
Flight distance : 82641 ft
Why not keep them all on the ipad, you will then be able to compare them, you dont have to use them but keep them just in case on has a problem, the others should still work. I have all three apps on mine with no problems, its a bit like people having the djigo app on but fly with litchi
2017-1-6
bsett
Mallettron Posted at 2017-1-6 09:59
Yeah that's probably what I'll do. It's actually kind of a mute point right at the moment since the Go Pro app isn't even available for the P4 pro yet.
I was just wondering if when you do firmware updates if that info is kept with the Go app that did the upgrade or if it's available to all.
2017-1-6
