High Flyer
Flight distance : 944642 ft
DJI Mindy Posted at 2017-1-5 02:39
The current is little. You don't need to worry about it. I'd suggest you to full charge the device, RC and aircraft battery before your flight.
Some figures to help illustrate: I've been told that P4 RC and P4P RC have the same capacity battery and the same power drain when in use. To fly my P4 until battery low took approx 7.5% power drop on my iPad pro 9.7". To fly a full battery in the same way with my P4P, uses 3.5% - 4% powerdrop on same ipad. To say current from P4P is little isn't really correct in this case. Is it possible that maybe the P4P RC battery is fine but the circuitry is faulty to cause too much power to be pushed from the RC to the iPad ?
End result is that I was getting near on twice as many flights from my P4 than my P4P with the same amount of power draw from the RC ? |
