Better shell for P3?
DanielJacobsson
Sweden
Wondering what the latest is on the bad shells to P3 are? If DJI has released or will release better shell that will not crack? If there is a manufacturing defect with the bad plastic mixture (as I understand it), then should not DJI sell new improved shells? I have no cracks but I suppose they will come, then I would like to switch to a better shell.
2017-1-6
DJI Natalia
Flight distance : 318 ft
If cracks happens to your aircraft sometime, please feel free to contact us, we'd like to help you evaluate it.
If it's caused by product faulty, and accord with our after-sales policy, then it will be covered by warranty.
2017-1-6
fansb62ad75b
Hello, I received a P3A for Christmas, sadly it had to be sent back yesterday after the 'stress cracks' appeared.... This is the second fault with the aircraft in as many weeks, had to send a batery back to them as well as it had a faultless cell...... not that impressed so far .......
2017-1-6
Stinky711
fansb62ad75b Posted at 2017-1-6 02:19
Do you have a photo of your "Stress cracks" or can you tell me where they are?
2017-1-6
DanielJacobsson
Sweden
DJI Natalia Posted at 2017-1-6 02:04
I have not encountered any cracks on mine, has barely adjustment used it.
It seems to be very common or unavoidable to get cracking. Wondering if you will make stronger shells for it, or if you need to buy a stock and changes each time there are cracks? How long is the warranty then? It does not feel good to send it around the world just to get a new shell that gives the same problem.
2017-1-6
fansb62ad75b
The cracks on one of the arms
2017-1-6
DanielJacobsson
Sweden
So I guess that Dji will not make a better shell for the Phantom?? and still sell the Phantom with shells that will get shell cracks in some time.
2017-1-7
Stinky711
DanielJacobsson Posted at 2017-1-7 23:47
There is a upgraded shell that has better support at the motor mounting points.
Here is a quote from DJI Natalia,
"If cracks happens to your aircraft sometime, please feel free to contact us, we'd like to help you evaluate it.
If it's caused by product faulty, and accord with our after-sales policy, then it will be covered by warranty."
So what is there to guess about? I have two P3Pro's with no cracks!
All things will fail in time with use. Choice is to fly and enjoy or worry.
2017-1-8
DJI Natalia
fansb62ad75b Posted at 2017-1-6 09:01
May I know have you contacted our tech support to report this case?
2017-1-10
DJI Natalia
We really understand your feelings,  we'll take care of the case if it happens to your aircraft and I've explained it.
2017-1-10
DanielJacobsson
Sweden
Stinky711 Posted at 2017-1-8 11:49
I have read that even the new shell cracks.
2017-1-10
DanielJacobsson
Sweden
DJI Natalia Posted at 2017-1-10 02:38
Ok, if I get cracks I will talk to you about it. I hope i dont get any. I hade two p2 with no cracks.
2017-1-10
RicardoGray
Flight distance : 4356421 ft
DanielJacobsson Posted at 2017-1-10 06:57
You will for sure get them. Almost guaranteed. There has been a lot of discussion about this. I know a lot of people including myself have used the "Weld-4" solvent to fix such cracks. It works extremely well and you don't have to take the shells apart. I suppose at some point I will have to replace the shells, but it is unfortunate that DJI does not improve the quality. Probably a cost issue with changing the tooling.
Don't get to freaked out if you notice some cracks. I had mine for a long time before any showed up and then all at once I had several. I have never crashed or hard-landed. I think the material just finally gives up.
2017-1-10
fansb62ad75b
I have sent back my aircraft to your Holland work shop, fingers crossed it will soon RTH ! I hope that they do not reappear .....
2017-1-10
Rnfaust
Flight distance : 734938 ft
Dji just announced on their website they have stopped production of the P3. So that should answer the question of any design changes. Their paper thin shell is great for maximizing flight times, but doesn't always hold up structurally, especially around the motors.
FYI: Mine is 1-1/2 years old, flown sensibly most every day and no cracks. (I did add StrongArm reinforcement plates under the motors though) However my camera just blinked out a few days ago. If a new flat ribbon cable doesn't fix it, Mavic - here I come!
2017-1-10
DanielJacobsson
Sweden
Rnfaust Posted at 2017-1-10 07:52
Ok, that was interestning. Hope that there is maby a new shell soon then. Will read about this later
2017-1-10
DanielJacobsson
Sweden
Where did you read that, I cant find it.
2017-1-10
Rnfaust
DanielJacobsson Posted at 2017-1-10 11:10
It was a popup when I went to my P3A download page.
http://www.dji.com/phantom-3-adv/info#downloads
I think the new shell design at this point is called Mavic and P4A.
BTW: found this in the description of the P4A: "The adoption of titanium alloy and magnesium alloy construction increases the rigidity of the airframe and reduces weight, making the
Phantom 4 Pro similar in weight to the Phantom 4"
That sounds good!
http://www.dji.com/phantom-4-pro
2017-1-10
Jtahan
Flight distance : 481601 ft
its crazy how many cracks im hearing about...ive had mine for just over a year now, flipped it on take off once, and crashed it hard from about 15-20 feet up...i inspected the hell out of it and i have yet ( knocks on wood) to see a crack.
2017-1-10
DanielJacobsson
Sweden
Rnfaust Posted at 2017-1-10 12:20
Thanks! Maby I will buy all the shells to P3 and make some money when people cant get them longer from Dji  ;)
2017-1-10
DJI Natalia
Jtahan Posted at 2017-1-10 12:46
Sorry for your crash, may I know have you contacted our tech support to create a repair case?
2017-1-10
Jtahan
DJI Natalia Posted at 2017-1-10 22:43
i actually needed a quick fix back when it happened so i ended up just buying a new gimbal/camera from you guys and went about my flying. The post above was more of me not understanding how so many are cracking from stress when my hasn't cracked from a solid crash
2017-1-25
