Violent Shaking
1810 15 2017-1-17
alkhaled
Kuwait
hi,,, my Mavic Pro is shaking violently while hovering. it sometimes shakes then remains stable for a while then resumes shaking if i move it. I caliberated IMU and updated software/firmware but the problem wont go away. Can anyone help? Thank you
2017-1-17
Griffith
Flight distance : 98537 ft
Check your props for damage.
2017-1-17
fansed5a4389
Flight distance : 36926 ft
Indoor or outdoor?
2017-1-17
softgrapes
make sure you don't have the propeller cage option enabled in the DJI GO app.
2017-1-17
mscarohaley
Have you had any luck? I am experiencing the same thing, I've tried everything to fix it to no avail. DJI tech support won't respond to me.
2017-1-17
watuse
Flight distance : 2064587 ft
mscarohaley Posted at 2017-1-17 21:19
check in the DJI app that the propeller cage is not activated this is the cause for the shaking.
2017-1-17
Heavysledz
Flight distance : 819491 ft
If it is not the propeller cage setting set to "On" then try reseting all of the user selectable parameters to default. Some folks reported this after screwing with some of the EXP or gain settings and a reset resolved the issue.
2017-1-17
DJI-Paladin
Flight distance : 2408 ft
Please make sure that the propeller cage option is disabled in the DJI GO APP. And then check whether the props are in good form. And also the GPS signal may affect the hover stability.
2017-1-17
E3exr1R5CKo6
I have the same problem. Could it be that one reason is when outside is less than 0 degree? It hapens to me often when it was -4 degree.
2017-1-17
fans672e9f91
They have stated there is performance issues at colder temps.  That's why they built in the heating element into the inspire 2.  Only other advice I can say is check the firmware, they did an update to reduce gimble shudder.
2017-1-18
13MStang
Flight distance : 892749 ft
see my video to see if its the same problem you are having... I was able to resolve.
2017-1-18
Angelo26
Flight distance : 799718 ft
Austria
13MStang Posted at 2017-1-18 05:31
https://www.youtube.com/watch?v=YwqG9X4A23E
That´s exactly how my Mavic behaved when I switched on the prop-cage-button in DJI GO app settings. After switching it off Mavic flew as ever ...................... Check if Prop-Cage-Button is SHUT OFF in the settings !
2017-1-18
alkhaled
Kuwait
GUYS.... PROPELLOR CAGE.... unchecked the propeller cage and the problem was solved.
TURN OFF PROP CAGE SWITCH
2017-1-18
alkhaled
Kuwait
oh and THANKS to all responses... cheers
2017-1-18
alkhaled
Kuwait
problem resolved guys.... just switch off PROP CAGE
2017-1-18
mscarohaley
alkhaled Posted at 2017-1-18 08:07
I switched mine off a couple of days ago, didn't help. I went back today to check it again, and now the option can no longer be found anywhere on either app (DJI Go or DJI Go 4). Where at in your app do you find the setting? I have searched high and low today
2017-1-18
