ActiveTrack while skiing
1500 7 2017-1-19
canistraccioil
Hi folks!
I'm going to use mavic while my son is skiing, on a little slope ski track.
Question: ActiveTrack mode will auto adjust the height while following the target, or shall I use the Terrain mode?
Any advice for best results?
Ciao
Paolo
2017-1-19
Peter Galbavy
Flight distance : 545377 ft
Unfortunately neither Active Track or Terrain Follow will descend. This is some sort of mad design choice by DJI.
2017-1-19
Angelo26
Flight distance : 799718 ft
Austria
Simply: NO !
2017-1-19
FlashGJ
Flight distance : 293379 ft
After extensive testing (and there are other threads about this) with the latest firmware/software Active Track will indeed both descend and ascend while tracking a subject. The real problem with using it for skiing is the speed of the moving subject. In my testing I found ActiveTrack to work reasonably well on slower moving subjects, but as the speed increases, it becomes more and more unreliable. Autopilot for iOS works great ascending and descending while in Follow mode, but it works by GPS and therefore follows the controller and must be moving faster than 3 mph. So it has its own pros and cons.
2017-1-19
hallmark007
Flight distance : 9827923 ft
What about follow me?
2017-1-19
Angelo26
Austria
Best procedure would be:
Shot 1: profile mode: start at head level approx. 5m away > follow for 30 secs. You might adjust vertical position of Mavic with the left stick slightly-slightly-slightly down
Shot 2: 5m ahead of target front slightly higher then head-position > follow 30 seconds. Again You might adjust vertical position with the left stick.
Shot 3: tracking- mode circling the target. You might adjust vertical position of Mavic with left stick
Be cautious: only slightly touch the left stick down otherwise the reaction will be too fast and target gets out of focus
Watch other people in the track of Your Mavic
Enjoy
2017-1-19
ePetLicensing.c
Hi,
Unless it is ONLY you and your son...X it. Safety First!
Protect animal population. Spay or Neutered your Pet!
2017-1-19
canistraccioil
Thank guys for your advices!
I'm going to try and let you know...
Ciao
Paolo
2017-1-20
