Gimbal Initialization
1592 3 2017-1-20
Jacky-Jonhy
Flight distance : 19239 ft
Dears,
I have just receive my mavic and i have a problem with the gimbal.
When i turn on the drone, after gimbal initialization, the camera is tilted.
I have calibrate the IMU, the gimball and i reboot but after initialization the do same problem.
I turn a little the gimbal tilt motor's and they work, the camera go imediately at the skyline
They work at all flight time but when i reboot this problem back again.
And when the drone is power on during a longue time but not in flight (firmware upgrade), the gimbal became hot.
If i reboot when the gimbal is hot the initialisation doesnt work.
the camera look down and i have a error message.
Should i return the drone ?
Thx
Adrien
2017-1-20
DJI-Ken
Flight distance : 1515312 ft
Can you post a video clip of exactly what you are talking about.The gimbal is correctly supported and when off it sits level and not tilted?
You can also connect it to the Assistant2 and restore to factory defaults and see if it resolves it.
2017-1-20
Jacky-Jonhy
DJI-Ken Posted at 2017-1-20 13:21
Can you post a video clip of exactly what you are talking about.The bimbal is correctly supported and when off it sits level and not tilted?
Thx for your quick anwser Ken,
Sure let see this two clip
First is when the gimbal its cold
the seconde is when the gimbal is hot (she became very hot you think is normal ?)
2017-1-20
DJI-Ken
Jacky-Jonhy Posted at 2017-1-20 14:51
Ok thanks, I see now. From the first video I was going to ask you to swipe from the right side of the screen to the left and that brings up another menu when you can get Portrait/Landscape.
I was going to ask you to do that but by looking at your second video it looks like the camera has a problem.
Can you connect it to the Assistant2 and restore the aircraft to factory defaults.
If it still has this problem then I think you need to send the aircraft in for repair.
It was never crashed or had a hard landing has it ?
2017-1-21
