doing something wrong
749 4 2017-1-29
Orlando_Jeff
Flight distance : 49147 ft
I'm trying to downgrade my go app. I downloaded the apk file but when I try to install it, my phone says..not installed. what am I doing wrong
2017-1-29
RedHotPoker
Flight distance : 165105 ft
Do you use iTunes?
RedHotPoker
2017-1-29
DroneGuy96
Flight distance : 8127 ft
If your using android you have to go into the settings and allow downloads from outside sources (if your trying to downgrade), otherwise you can download the most recent  version directly from the google play store.
2017-1-29
RADROCKET
Flight distance : 1110827 ft
I used APK, but make sure you pick earlier than 3.1.1, like 2.9.1 .  if you look into your drop down notifications there it says download complete , click on that. It will open the go app.
Google maps wont show up till you restart your phone. then do a compass re cal. and an IMU recal
2017-1-29
Betamace
Flight distance : 2133 ft
You did completely uninstall the bad app first and then reboot? If your mobile device is set as per post #3 it should flawlessly download and install the apk. If you downgrade any app, be sure you turn off auto updates in Play Store settings or it will just upgrade again.
2017-1-29
