Gimbal calibration complete at 66%
658 10 2017-2-1
fans5916e3a5
Flight distance : 1273064 ft
I've done a IMU calibration with only .0005 degrees on being perfect on the horizontal. Also calibrated compass. I calibrate the gimbal several times,but it never goes above 66%, but.says the calibration is complete. My question is how do you know if the gimbal is 100% complete if it only shows 66%? Maybe this is the reason for the tilted horizon because the gimbal calibration isn't complete, but the dji go app says it is. I've calibrated everything so many times, but the tilted horizon is still tilted. Hopefully someone will have a permanent fix....
2017-2-1
RedHotPoker
Flight distance : 165105 ft
I know several forum members here, have successfully fixed a crooked horizon, with their Phantom 3 gimbal, by doing a chilled drone IMU calibration, followed by the gimbal calibration.
I'm unsure, if this procedure, would also fix the Phantom 4 crooked horizon issue as well?  You could try it and see... ;-)
RedHotPoker
2017-2-1
fans5916e3a5
RedHotPoker Posted at 2017-2-1 02:10
I've already  done that so many times , but it didn't  help. I've  calibrated everything so many times it not funny anymore . Thanks  for your help. I think it is in the firmware. I've  even done a firmware update several times that didn't  help either. Have you seen the gimble calibration  that I'm  talking about?
2017-2-1
Nigelbrinkmann
Flight distance : 586391 ft
fans5916e3a5 Posted at 2017-2-1 02:26
Hi dose the calibration go from 66% to complete? how long is this period between 66% to complete?
If the horizon is still tilted you will be right in saying that it may be a FW issue depending how bad the tilt is
Have you tryed to roll back FW to see if it helps?
2017-2-1
fans5916e3a5
Nigelbrinkmann Posted at 2017-2-1 02:36
About 2 seconds.
2017-2-1
fans5916e3a5
Yes I've  done a rollback  with the djigo app,didn't  help. The djigo 4 does the same thing  I  think when dji does a firmware upgrade that issue isn't  address. So when dji upgrades the issue is  still there because  that part of the firmware wasn't  change  so it just gets  passed along on the next update. Thanks for your help.
2017-2-1
RedHotPoker
So You have chilled the drone down good in the fridge, or in front of an air conditioner before beginning the IMU calibration?
Ok, Not sure what else to recommend then...
RedHotPoker
2017-2-1
Nigelbrinkmann
fans5916e3a5 Posted at 2017-2-1 02:49
How bad is the horizon tilt? could you post a pic?
2017-2-1
fans71e23c5f
Flight distance : 2535420 ft
I had the same problem with tilted horizon. After imu and gimbal calibration didn't fix the problem I used the gimbal roll option in camera to straighten horizon.
2017-2-1
Aardvark
Flight distance : 384432 ft
The horizon 'tilt' can be adjusted in flight using the RC 'shortcut' of holding C2 button operated, and while C2 operated adjust tilt using right hand wheel on controller. There is also a grid pattern appears on screen to assist.
2017-2-1
Jambond54
Aardvark Posted at 2017-2-1 06:07
Thanks for your response.  I know how to do all that. The issue needs to fixed by dji.
2017-2-1
