Dji go APP Problem
870 8 2017-2-5
Darrel1987
Hello guys I'm new to the forum.
This morning I took my P3S for a flight which was fine.
I then went for a flight this evening ( different location )
Re calibrated drone, took it up to approx 50ft and I loose all signal on the app. I then come back to approx 20ft and will all come back again.
I am using iPhone 7 plus so not sure if this is okay? But baring mind it was ok this mornings flight.
I have updated to latest firmware and I'm reading to downgrade the firmware to previous Version but I'm not sure if this is the best thing to do :/
Hope you can advise me
Ps nice to meet you guys!
Daz
2017-2-5
Darrel1987
Or is this the same issue as what everyone is saying regarding the update?
2017-2-6
DJI Natalia
Flight distance : 318 ft
Please make sure you adjust the antenna to the optimal range during flight.
And try to fly it farther firstly, then higher.
Besides, you can re-link aircraft and remote as well.
2017-2-6
Darrel1987
Hi thanks for that, however I have the antenna pointing up. (This is all I know) regarding when u say I can re link ac to Rc what do u mean by this.
Thanks again
2017-2-6
DroneGuy96
Flight distance : 8127 ft
Here is what he means by relinking the controller, http://wiki.dji.com/en/index.php ... l-Remote_Controller . This should provide all the necessary information on relinking the controller.  If relinking the controller doesn't work my next step would be possibly downgrading the FW.  I had the same issue that you described after I updated my FW. I am now using 1.7.9 and all seems fine again.
Good luck!
Cory
2017-2-6
Darrel1987
Thank you Cory much appreciated!
2017-2-6
Darrel1987
Cory I have a 3 Standard will this be the same process?
2017-2-6
DroneGuy96
Darrel1987 Posted at 2017-2-6 11:15
yes the procedure is the same!
2017-2-18
fans6aa321cd
Flight distance : 26 ft
DroneGuy96 Posted at 2017-2-18 13:35
How ? i do the things they say and all i see is "No available firmware for downgrade"    version 1.8.10   Sorry is this for the RC?
2017-2-18
