Strange squiggly line on footage!!!!! :O
951 2 2017-2-10
fans49a8f4dc
Hi all, I have just setup my drone a few days ago and have had a few test flights. I have been getting these strange lines/distortions on my footage (in particular see 0:20 of the attached clip). These unusual markings tend to be worse when I move at high speeds. Note that when I took the gimbal cover (bubble cover) off these distortions went away... so something to do with the bubble. has anyone experience this or have a solution. https://youtu.be/z0CwY0Jr7Do
Thanks!!
2017-2-10
Tharg (from the
Flight distance : 120784 ft
You are either flying with the bubble on or you have a contaminated camera with something behind the front element moving with airflow.
2017-2-10
CuaC
Flight distance : 369626 ft
In your own post you've got the solution: Note that when I took the gimbal cover (bubble cover) off these distortions went away... so something to do with the bubble. has anyone experience this or have a solution.
That's it... remove the gimbal cover. It's mean for transportation, and while you can fly with it, it will produce additional artifacts. If you want to add some extra protection plus sun shade, you can find online gimbal covers colored in black and with the central section removed (so the camera FOV is not affected)
2017-2-10
