Aircraft Battery - History- Undervoltage Protection due to over discharge
2863 15 2015-2-20
GB44
Flight distance : 343848 ft
When entering the battery mode on th IOS App, then enteringteh History mode, I have an entry in Record 06 that states:
"Cell undervoltage protection due to overdischarge"
This text is highighted in red  on the app so I assume this is a bad thing ?
Can Ed Tahoe or someone from DJI shed any light on this.  There is 31 Records in total and everything before and after entyry 06 states  "Normal"
Any reason why the Flight Time has also reamained on 00:00.  I can reply privately  to you Ed if necessary.
2015-2-20
vonbaron1
Flight distance : 42014 ft
GB44,   I have a entry with the same error but what makes this more odd is I just got a new TB48 today and did the history check on it and it already has this error in it and it's never been used by me and not even been charged to full yet.
2015-2-20
Chris Con
Flight distance : 501175 ft
Vonbaron1-  Total speculation here, but every single TB48 I've purchased so far has also had that error in the battery history.. Grain of salt here- But they probably rapid cycle the battery causing that error before shipping.  In other words, they test the battery before they ship but need to fix that showing up in the battery history. Here is a screen shot from a virgin TB48 I received an hour ago in the mail.
2015-2-20
Blade_Strike
Flight distance : 872694 ft
Correct, this should disappear with use. If you continue to see it I would contact support.
2015-2-20
gabriel_rinaldi
I have the same problem with all my batteries: http://gnr.me/1lo65
2015-2-20
GB44
Blade_Strike Posted at 2015-2-21 10:23
Blade,
When you say it should go away, can you clarify how and after how many re-charges or flights ?
2015-2-21
Mike-the-cat
Flight distance : 22488593 ft
Singapore
Seems like this is a bug - I encountered this message when discharging to below 20% 'at rest' i.e. not flying. I've used the battery 10x now, no problems at all
2015-2-21
GB44
Ok,
I charged the battery again after a short flight, (Post Flight Charge was 47% remaining).  After re-charging, I installed back into Aircraft and there was a whole host of red text records in virtually every entry.  Switched off aircraft, transmitter and app then powered up all again and all have now dissapeared except for the original record  06 entry  "Cell undervoltage protection due to overdischarge"  which is still there.
So unsure what is going on here.
I will certainly be checking the battery status after the next re-charge.
2015-2-21
Blade_Strike
That record should fall off. Now if you get constant errors about over discharge and your not taking the battery down to the low voltage setting, that's when you could have a problem.
2015-2-21
GB44
Blade_Strike Posted at 2015-2-22 02:24
That record should fall off. Now if you get constant errors about over discharge and your not taking ...
When you say not taking the battery down to the low voltage setting what do you mean.  I thought these batteries were automatic and could be charged at whatever post flight charge remained.
As I said the battery level was 47% when I last charged it.  So unsure if I am doing something wrong here
2015-2-21
Blade_Strike
They can. But you shouldn't see any more logs about over discharge unless you over discharge.
2015-2-21
GB44
Blade_Strike Posted at 2015-2-22 02:40
Thanks Blade,
I will keep an eye on the battery record history.
With regard to Over Discharge, what is the minimum % remaining.  The manual simply says discharge untill less than 8%.
Blade, do you work for DJI ?  If so do you have a direct email as I have a few questions about frequency and power that I need answers for to complete a commercial Operations Manual.
2015-2-22
Visual Air
Flight distance : 2710115 ft
GB44 Posted at 2015-2-22 23:39
Thanks Blade,
curious as to what battery firmware you have?
2015-2-22
GB44
Visual Air Posted at 2015-2-22 23:56
Where is the battery firmware displayed in the App
2015-2-22
Visual Air
GB44 Posted at 2015-2-23 01:01
Under about.....
where you can view all the other software versions, guessing it should be 3.00 but maybe 3.03
2015-2-22
GB44
Visual Air Posted at 2015-2-23 06:24
Under about.....
where you can view all the other software versions, guessing it should be 3.00 bu ...
here are my settings:
App Firmware 1.0.1
Center board  Firmware: 02.03  Loader : 03.00
Air OFDM  Firmware 01.03  Loader 03.00
Battery Firmware : 0.3.00  Loader 02.06
Ground decoder  Firmware: 01.03  Loader 01.00
Ground OFDM  Firmware:  01.03  Loader 02.00
Main Controller Firmware : 01.15  Loader 34.01
Just powered up again and a whole raft of red warnings up to Record 8.
e.g.: Record 01
Over Temperature in discharge
Low temperature in discharge
cell under voltage protection due to over discharge
cell Broken
Time to discharge
Aircraft power now at 67%
Controller at 31 %
Will now re-charge both Controller and Aircraft Battery TB47 and see what records show up
2015-2-23
