What ND filters do I need?
1906 12 2017-2-14
samtay32
Good day, all. I just purchased the P4P for stills and 4k video. I've been looking into ND filters and I'm still a bit confused on what to get. What filters should I get for taking stills and what should I get for shooting 4k. Thank you all for all your help.
2017-2-14
Grizz 1
Flight distance : 120066 ft
nd filters, 4, 8, 16, 32. I have used all of these in different places and times of the day.
2017-2-14
WindSoul
Flight distance : 16 ft
i believe the p4pro variable aperture is a good get around to filters. i own a p4 and f/2.8 combined with shutter speed up to 1/4000 is amazing. add variable aperture to that! other than to take close shots in extra strongly illuminated subject (not really the purpose of a wide lens), i dont see a use for filters.
2017-2-14
theGrindLab.com
Flight distance : 1375846 ft
There is no "right" filter for stills vs video. ND filters all do the same thing. In simplest explanation:
The number just indicates how much light they cut. The higher the number, the more light they cut.
This applies not matter if your images are still or moving. For video, this may be more important due the fact you'll be shooting at specific shutter speeds to get the look you want, and in those situations, you cannot just increase your shutter speed to reduce the amount of exposure time. An ND filter gives you flexibility. Of course, this applies to stills as well.
2017-2-14
samtay32
theGrindLab.com Posted at 2017-2-14 16:29
The 3 filters DJI is selling right now for a minimum 1 month ship time at best.
So I went to PolarPro and they have 7 filters for the Phantom 4 Pro, one of they being just a UV filter (does the P4P come with a generic UV filter?), can you all take a look and tell me what you think about the 2 different lens series they have.
What are your thoughts? Would it be wise to get the pack of 6? One of the series doesn't come with an ND4 but the other comes with an ND4/PL.
PolarPro Phantom 4 Pro ND filters
2017-2-15
MathiasK
Flight distance : 715860 ft
I currently own a phantom 4 and am going to upgrade to the pro when I get the Money needed. I was curious if the Polar Pro filters are compatible between the p4 and p4p?
2017-2-17
sd603
Flight distance : 274465 ft
http://www.ebay.com/itm/26284595 ... =STRK%3AMEBIDX%3AIT
2017-2-18
sd603
Here are cheaper options on eBay.  I bought CP, 4, 8, 16.  ~$10 each, shipped from China.  Case for $7.  Total cost $50
2, 4, 8, CP
16
Case for filters
Now if I can find a petal style lense shade for the P4P...  Anyone?
2017-2-18
BIGDZ
Flight distance : 10255860 ft
sd603 Posted at 2017-2-18 07:17
2, 4, 8, CP
How are these working out for you? Good quality thx
2017-2-20
Helimage
Flight distance : 144140 ft
Finland
Different filters for different circumstances, but if I had to pick one, it's definitely ND8. On a sunny day, it's usually overexposed with f/2.8 and underexposed at f/11, so you can choose a value between those numbers without touching the shutter speed or ISO.
2017-2-20
fansb367b23c
Flight distance : 49783 ft
I would highly suggest these -
Phantom 4 Pro Polar Pro Filters
2017-2-20
Cabansail
Flight distance : 136686 ft
The filter sets will ussually have 1 Stop between them and often miss the first Stop
ND4 is -2 Stops
ND8 is -3 Stops
ND16 is - 4 Stops
ND32 is - 5 Stops
Each Stop is half/double the light. So with a fixed Aperture 1 Stop would make the shutter speed twice as long.
eg. No Filter ISO100  f2.8  1/1000th with an ND8 fitted will become  ISO100  f2.8  1/125th. To get 1/60th you would fit the ND16 instead.
From experience the more expensive filters have less colour cast than the cheaper versions. The choice is to spend the money and know it is OK or save the money and spend a few seconds in Post to do a correction. Personally I save the money and correct as it's something I would be checking anyway.
2017-2-20
samtay32
fansb367b23c Posted at 2017-2-20 14:58
Aren't those ND filters kind of high for everyday use? What do you think about their 4ND/PL 8ND/PL and 16ND/PL? Would those be a good choice for photos and video and everyday use? I'm live in Texas so there aren't as many opportunities to block out snow or water as much.
PolarProFilters
2017-2-22
