Flight height without GPS
3002 8 2017-2-17
fansb8da9fad
Flight distance : 2005745 ft
Belgium
Dear,
I'm a professional drone pilot and fly with Inspire, S1000+ and Mavic.
We use the Mavic mostly for indoor flights.
I have a problem with the flight height indoor when you have no GPS signal available.
The Mavic only wants to fly 2,4m above the surface.
But when you fly in a large hall which is 5m high, you can't go up above 2,4m.
Is there an option to fix this issue? I can't find it...
Kind regards,
Sander Gheldof
2017-2-17
Ex Machina
Flight distance : 1806362 ft
From the owners manual, v1.2, pg 49:
Height is restricted to 16 feet (5 meters) when the GPS signal is weak and Downward Vision System is activated. Height is restricted to 98 feet (30 meters) when the GPS signal is weak and Downward Vision System is inactivated.
I think you should read "when the GPS signal is weak" as when the Mavic is in ATTI-mode.Hope this helps.
2017-2-17
Ex Machina
Re-reading your post, it does seem odd that you can't go but half the height you should be able to go -- try turning off the Downward Vision System to see if you can go higher as stated in the manual.
2017-2-17
dronist
Make sure your RTH is set to HOVER...
2017-2-17
lildevilx
Flight distance : 264101 ft
dronist Posted at 2017-2-17 08:02
better yet, throttle down.... Would kinda suck to just watch it hover there and can't connect....
2017-2-17
dronist
lildevilx Posted at 2017-2-17 08:20
In case of lost GPS it will activate RTH and you don't want it to go thru the roof
2017-2-17
lildevilx
dronist Posted at 2017-2-17 08:24
a. We're talking about when there is no GPS signal
b. either Hover or decrease thorttle/land won't have it go thru the roof. (This will force the mavic to land where ever it at, at that moment in time
2017-2-17
DRONE-flies-YOU
Flight distance : 1450594 ft
lildevilx Posted at 2017-2-17 08:33
Landing immediately is dangerous & unprepared.  That doesn't seem like the prudent choice here.  Hover gives you time; whereas landing RIGHT NOW could have dire consequences.  Just because it is 'inside' doesn't lessen the threat.
2017-2-17
dronist
DRONE-flies-YOU Posted at 2017-2-17 09:51
Second that... The issue is when RTH is forced then HOVER is the best solution to prevent a disaster.
2017-2-17
