propeller attachment kit for ph 4 pro plus
1426 10 2017-2-21
madpaddy73.opto
Hi the other day a propeller blade was being stubborn to remove the end result was that i cracked one of the small plastic pieces next to the spring ,it seems fine wien i attach another blade but i dont want to take the chance ,anyone have a link to where i can get a replacement ,ive seen them on amazon but it says Ph4 only not for use on ph4 pro plus..thanks Guys you rock..
2017-2-21
dronist
You can use the following sine the propellers from P4 can be used on the P4P AND P4P+ :   http://store.dji.com/product/pha ... ng-plate-cw-and-ccw
2017-2-21
madpaddy73.opto
thanks but it says not compatible with ph 4 pro ..
2017-2-22
Snowwolfwarrior
Flight distance : 1064780 ft
Think there is a bigger hole in the middle of the p4p version, I may be wrong but thought at the time it was only a matter of drilling them out
2017-2-22
dronist
madpaddy73.opto Posted at 2017-2-22 09:01
You are right... My mistake!
I guess search for a someone who already trashed their P4P or contact DJI see if they can send you one?
2017-2-22
lefgrter
Flight distance : 139738 ft
Greece
Hi my friend I cracked mine since first week that i had the drone. (20 of December). I bought the P4 mounts and I noticed that the hole was smaller and had to be drilled to fit the spring of P4P. I decided not to drill it and used the P4 metal spring. Since then my P4P covered many many Kilometers (miles!!) with no problem at all. Of course when Dji decides to release the proper mounts I will change it but till then there is nothing else to do. (Of course you can send it back for repairs!!!!! or kindly ask them to send you a set).
2017-2-24
madpaddy73.opto
hi guys  ,I ordered the ph 4 set from amazon and yes the only difference is the size of the hole ,so with that I drilled out the center and fit the coil through ,seems to work great so far no problems .
Thanks J.
2017-2-27
MrWhite
Flight distance : 272 ft
madpaddy73.opto Posted at 2017-2-27 04:39
Thanks J.
Interesting, but I would be very concerned with modifying any OEM part especially one that is critical to flight. That being said, I'm glad that you are willing to risk your aircraft in the name of expanding knowledge concerning compatibility issues.
2017-2-27
rparge
Flight distance : 173852 ft
Hi, I had the same issue, the P4 Series prop mount kit in the DJI store works great with no mods necessary.
You just have to use the P4 spring.
http://forum.dji.com/thread-79369-1-1.html
2017-2-28
lefgrter
Greece
DON'T DRILL it. Doing that you may create a small (hairline) crack on the part. (you probably wont see it). That part takes a lot of vibration and evantually might break at some point and loose the prop!
The P4 spring works just fine.
2017-2-28
sd603
Flight distance : 274465 ft
I don't recommend drilling the p4 mount out for the spring to fit. 1. The bottom of the pro mount has a recessed bevel for spring to sit in - so a simple drill out won't work.  2. The pro mount bottom is not the same thickness as the p4. I believe screws may be different.
Solution - simple replace the full profile mount with the p4 mount including using the flat spring instead of the coil springs. I've done it and it is perfect fit
2017-2-28
