[Resolved] Impossible to update Mavic through DJI Go 4 on LG G4
836 5 2017-2-21
ChrisNiceButDim
Morning all,
Connected to Mavic with DJI GO 4
App showed a firmware update was required so came back out into home and clicked on update. It takes me to a screen as attached and no button to download or update, just info about the update. Reconnected and restarted the app countless times. Impossible to update. Has anyone had similar issues? Please advise.
Kind regards
Chris
2017-2-21
Soarmax
Flight distance : 7536 ft
A couple of things come to mind. First try uninstalling and reinstalling DJI GO 4 App.  If that doesn't solve the problem, you should be able to update your Mavic and Controler using DJI Assistant 2 from your computer.  Please let us know how these work out.  - Max
2017-2-21
4wd
Flight distance : 545817 ft
I think there's a 'button' obscured by that text on smaller screens or the way some phones display it.
The Assistant is the way  to go.
2017-2-22
K4Unl
Flight distance : 122175 ft
Try setting your font to the default, I noticed on my G4 that the button was barely visible (and i have everything set to small)
2017-2-22
ChrisNiceButDim
Thank you guys.
As you suggested it was down to the text. Reverting back to the default text style alone didn't solve the problem but changing the text size to the smallest size just about allowed me to see a slither of the button. Think the App scaling needs a little attention.
Kind regards
Chris
2017-2-22
SupraLB
Flight distance : 1594 ft
Same thing happened to me on my LG V20 yesterday.   I tried everything, from rebooting to closing everything, and even came here looking for a solution.
It finally worked when I had to swap out the battery in the Mavic, because it was draining down the whole time.    Once I did that download button finally was completely visible.
2017-2-22
