The laster upgrate has created problem in the picture
580 7 2017-3-1
nikos8
Greece
Hello, the latest upgrade for the phantom 4 has a large problem in the picture that transmits on tablet. The picture is lost per 2 seconds and shows up only black.
Can someone help me to solve this problem?
Thanks.
2017-3-1
Aardvark
Flight distance : 384432 ft
Have a look at my post HERE, also have a read of all that thread, and my comments in post number 10.
2017-3-1
nikos8
Greece
Aardvark Posted at 2017-3-1 02:52
Hi,
I did downgrade not to 1.6 but to 1.5 by mistake (for p3) . Νow the controller and phantom4 it is not communicate. The controller It seems to be p3 in DJI GO and does not accept the upgrade to 1.6 or 1.8. What can I do?
Thanks
2017-3-1
Aardvark
nikos8 Posted at 2017-3-1 06:19
Hi,
Thanks
Firstly try 'resetting & relinking' RC & Aircraft'. This 'pairs' the RC to Aircraft.
Try to reset the RC:
* Turn on the controller, and the aircraft should be off.
* Press C1, C2, and shutter (top right button nearest antenna) on the controller and hold until it beeps, then turn the controller off.
* Turn on both the aircraft and the controller and link the remote.
I would recommend manually relinking the RC by performing the following;
* Turn on both the aircraft and the controller.
* Press C1, C2, and the record button (top left button) on the controller, then the controller will beep like D-DD.
*Let go all fingers, press the wheel on the right side of the controller and then the first light of the controller will become blue and it will constantly beep DDDD.
* Use a pen to click the linking button on the aircraft and hold for 3-5 seconds, and then take the pen off the aircraft and wait, it will be linked soon.
2017-3-1
Aardvark
Hi,
Thanks
Note that the right hand wheel on the RC does 'click' like roller wheel on a mouse.
2017-3-1
nikos8
Greece
Hi
I press the buttons and do not make a sound..
2017-3-1
Aardvark
nikos8 Posted at 2017-3-1 07:47
Hi
Hold them all operated together for about 3-5 seconds you should get a bleep.
2017-3-1
nikos8
Greece
Aardvark, Thank you very mach!!I
Finally not unblock the controller with the pressure on buttons. But I managed and did the upgrade to 1.60 firmware, and now works excellently !!
Thanks!
2017-3-1
