Latitude and Longitude
3220 5 2017-3-7
SkyFlyMike
Flight distance : 575167 ft
If I'm unable to get to a location and I need to check the longitude and latitude of the location,
what is the best way to obtain the numbers. I have an app that does it but you have to be
there.
Thanks,
Michael
2017-3-7
blackcrusader
Flight distance : 689774 ft
Taiwan
You can start with google earth.  However you you go to google and type in latitude and longitude for known place.
The issue I guess is large tracts of land using one name.
2017-3-7
Nigel_
Flight distance : 388642 ft
If you use normal Google maps, you can right click on a point on the map and choose "What's here?" and it will give both a name and a Latitude,Longitude.
2017-3-7
SkyFlyMike
Nigel_ Posted at 2017-3-7 11:20
Thanks. Pretty simple.
2017-3-7
blackcrusader
Taiwan
Nigel is full of good advice.  This forum rocks for that.
Enjoy playing with google earth and google maps
2017-3-7
Rvrrat14
Flight distance : 655932 ft
You can also use GS Pro and create a Waypoint mission.   It will record XYs for each point you create on the map.
2019-5-23
