Download Maps for iOS
3251 6 2017-3-16
DGBarar
Since the release DJI go 4.0.5 some users are reporting the ability to download maps.  This new feature is different from map caching included in previous releases of the DJI Go 4 application.
Does anyone know if this new feature is supported in the iOS version of the DJI Go 4.0.5 application.
Donald Barar
2017-3-16
DJI-Ken
Flight distance : 1515312 ft
The map is working the same way as before for me.
2017-3-16
fansb2edd25e
Flight distance : 736775 ft
It doesn't appear to.   I downloaded  the latest go 4 to a android and ios device.    The map option wasn't given on the ios but was on the adroid
2017-3-16
DGBarar
fansb2edd25e Posted at 2017-3-16 18:54
Hi Fans,
I have posted this question on Phantom Pilots and DJI Forums and have received numerous replies.  None of them remotely answered the question that I was asking.  You are the first to read, understand, and specifically answer the question that I asked.
Thank you so very much.
Donald Barar
2017-3-17
rparge
Flight distance : 173852 ft
There is a "Cache Map in Background" on the iOS three dot menu that is not on the Android version.
I read that you make sure that is turned on, then expand the map and move around where you wish to fly. Do not turn off the iOS device, as the cache is cleared when powered down.
If anyone can verify this is how it works on iOS?
Thanks!
iOS Map Cache
iOS Map Cache
2017-3-17
DGBarar
rparge Posted at 2017-3-17 09:53
Hi R,
What you are describing is map caching.  This has been a feature of DJI Go 4 since it's release (a potentially in previous versions of the application).  However, with the release of 4.0.5 a new feature was describing which allowed  for the downloading of a map in advance.  This is different then the caching that you described.
In an earlier response, "Fans" confirmed what I have suspected that downloading of maps is a feature only available on the Android version of the application.  If you are using iOS, then we only have map caching as you described.
Donald Barar
2017-3-17
Bone Saw
That would be nice! Also anyone know how to have the map follow the 'arrow' of the drone when viewing in map mode? similar to when you use the gps feature of the map app on iOS? It stinks to have to zoom way out so that your 'arrow' doesn't fly out of the screen on a 'no image transmission RTH'
2017-3-19
