Can't upload or view flights in flight record
807 5 2015-2-26
derkoi
i was hoping an update would fix the issue but it didn't. I'm using an iPad air 2. When I try uploading it says 2 upload errors (I have 2 flights) and if I try to open a flight the app crashes.
Anyone else getting this?
2015-2-26
DJI-Autumn
Do you use the latest app version?
Is the issue still here?
2015-3-2
derkoi
Hi, yes just installed the latest version and it's still doing it.
2015-5-8
jlivingston6
Flight distance : 82556 ft
Are you using the white arrow on the right side of your screen In the video and picture box to copy your flights into your pilot log? I land then while both the bird is on and the transmitter is on I press the white arrow and one of the options is to copy the flight into your log. That is the way I do it and it has always worked for me. I have not tested this function since the newest update as I have not been able to fly due to high winds. I don't know I'd this is what you are talking about or not. Hope this helps.
2015-5-8
PeteGould
I'm on an iPad Air 2.  Have had no problems with previous versions.  Will be testing the newest version of the app tomorrow.
2015-5-8
leoamartinez
Flight distance : 1602986 ft
Dominican Republic
I have an issue too, when i finish flying the records shows up on the app, but if try to synchronize it, it starts a progress bar, it only gets to 3% and closes, neither i could open a replay of the flight, could someone explain me the way of doing it, have an Ipad Air 1st Gen...
2015-5-9
