Mavic Just arrived. Bad Video??
899 7 2017-3-29
ckizer
Flight distance : 369177 ft
My Mavic just arrived. I did the firmware update, and all I see is this for the video feed. I'm freaking out, what's going on? I'm using iPhone 7 Plus
Do I have a defective unit?
2017-3-29
Asainz320
Flight distance : 1061594 ft
Remove the SD card and see if it still behaves the same.
2017-3-29
Flybee
Flight distance : 2203983 ft
Sweden
Reinstall the app and try again.
https://forum.dji.com/thread-76913-1-1.html
2017-3-29
SkunkWerxs
Flight distance : 231217 ft
Flybee Posted at 2017-3-29 12:39
Yes
I would try to install FW again then try
2017-3-29
Ex Machina
Flight distance : 1806362 ft
Another thing to check would be the cable -- use your iPhone's Lightening cable and see if that works.
2017-3-29
The Rev
Flight distance : 1256837 ft
Asainz320 Posted at 2017-3-29 11:04
I second this as if you have a corrupt or incorrectly inserted SD card you get a similar display and also try using the port in the middle of the controller with your own cable.
2017-3-29
R&L Aerial
Flight distance : 298100 ft
Are you filming a golf course?? If so it doesn't look to bad?
2017-3-29
Did you enable the hardware decoding from DJI GO app?
2017-3-30
