hallmark007
Flight distance : 10017858 ft
If you are a commercial pilot you would know that you always have to get permission for controlled airspace, it shouldn't be that difficult, you contact the proper authorities submit your plan and timescale, then let ATC know your there, there are reasons why you have NFZ and maybe the airport may not be so busy, but without contacting ATC and checking Notams, you run an unnecessary risk of causing problems for yourself and others.
If it is a big job and lots of money, then it's worth it to go through the proper channels, |
