dji go app wrong connect info
998 11 2017-4-5
pete m
Flight distance : 4803 ft
I downloaded dji go app on a nexus 7. When I clicked how to connect it is not showing the right controller in the diagram and says to use a USB cable to connect.My nexus was made after 2013 but there is no USB port on it. Does this sound right?
2017-4-5
DJI Natalia
Flight distance : 318 ft
You have the phantom 3 standard, right? have you connected the phantom WiFi properly?
There should be "Camera" button when running the APP after all are connected.
2017-4-5
pete m
DJI Natalia Posted at 2017-4-5 23:11
I have the standard.My Iphone 5s works app works fine.The screen is way to small,thats why I want to use the Nexus.Will try going through the settings.Thanks
2017-4-6
pete m
pete m Posted at 2017-4-6 05:49
Thanks I got it to work.But the instruction on the app for connecting the p3s are definitely wrong.they tell you to hook up usb cable to rc and tablet,as far as I know there is no usb port on either device. Maybe you can check this out and save someone some time.
2017-4-6
G_Sig
Flight distance : 9109311 ft
Iceland
pete m Posted at 2017-4-6 06:27
It is like this.
2017-4-6
DJI-Jamie
Flight distance : 112405 ft
Just to clarify, which Go app version do you have on both devices? When you use your phone do those instructions look the same?
2017-4-6
G_Sig
Iceland
DJI-Jamie Posted at 2017-4-6 14:35
Its just new users which see this. I just tested to force stop the app and clear all data from the app.
Then this pops up if you have not linked the RC AC.  I'm on 3.1.5 on android and  it all works well.
This was just test as I have newer seen this before.
2017-4-6
DJI-Jamie
G_Sig Posted at 2017-4-6 15:29
I'll notify the appropriate team to get this corrected.
2017-4-6
WilliamM
Flight distance : 904364 ft
Not that you need a USB cord with the P3S, but just to be clear you do have a USB port on your tablet. It's the same port you charge it from. Also do you have the 2nd gen Nexus 7 ? That's what I have, the 1st gen Nexus is not a good one to use with the Go app.
2017-4-6
DJI Natalia
Nice to know you made it.
I've forwarded this concern to the designated department to improve it, thank you for your feedback.
2017-4-6
adfp_88
Hi guy, thank you for your feedback.
I will fix this problem in the next version of DJI GO.
Thank you.
Best.
2017-4-6
DJI Natalia
Our engineers  are aware of this case and will fix it with the next version.
They replied this thread at 11#.
2017-4-7
