DJI Charging Hub
975 5 2017-4-24
Nevillejp
Flight distance : 703684 ft
New Zealand
I have the DJI Charging Hub for the Phantom 4 and have just noticed that in Storage Mode it will not discharge a battery that is at 100%, plug the battery in and the 4 green lights on the battery turn on but the light on the charger stays RED, run the battery down to 98% and it works fine, anyone esle notice this problem?
2017-4-24
Antonio76
Flight distance : 144403 ft
Denmark
I never had to discharge a battery that was still at 100%, so I don't know if my hub would do the same, so far it has acted like the manual says, RE the Status LEDs. Next time I charge my batteries I will try, though. Are you talking about a "normal" P4 Battery, or the new more powerful one ? The charger may be set for the old ones and show a different behaviour with a more powerful one, but i doubt it. Also, is the charger connected or not? (If the battery  you put in discharge mode is at more than 50%, the charger doesn't need to be plugged in).
2017-4-24
dronist
I don't see any needs to do that unless you are an International photographer and you have to board a plane in an hour???
Just kidding... but now I am curious. I will try it on both P4 battery and P4P battery and let you guys know.
2017-4-24
dronist
UPDATE... I tried to discharge P4P battery whihc was 100% full and kept it for 2 hours did NOT budge. I tried a P4 batteey which was at 100% full and same thing, it won't discharge in the hub!
2017-4-24
Nevillejp
New Zealand
Antonio76 Posted at 2017-4-24 13:30
You're right, there is probably no need to discharge a full battery but  it looks like the Hub is in need of a firmware update to allow it if you ever did need to.
2017-4-24
Nevillejp
New Zealand
If the charger is NOT connected you can insert a Full Battery into the Hub then power the battery on and it will show a blue light and discharge the battery, just doesn't work when the hub is connected to the charger so looks like like the hub needs  needs a firmware update to fix it.
2017-4-24
