Battery firmware update question
1308 6 2015-3-5
Joeyend1968
I just did the firmware update on my I1.  I have 3 batteries in total.  Do I need to restart the update process with the two remaining batteries?
2015-3-5
Skywolf007
Flight distance : 2758875 ft
Slovakia
From my experience and info from DJI support, if there is a battery update in the firmware it will be automatically update if you insert a new battery.
2015-3-5
Joeyend1968
Skywolf007 Posted at 2015-3-6 08:04
From my experience and info from DJI support, if there is a battery update in the firmware it will b ...
Thanks for the reply!
So do I leave the firmware update software on the SD card?  or the I1 does this internally?
2015-3-5
Skywolf007
Slovakia
Joeyend1968 Posted at 2015-3-6 08:07
So do I leave the firmware update software on the SD card?  or the I1 does  ...
When I called the phone support, they told me there is no need to leave update files on the SD card. I think its logical, since the Inspire already has the newest update installed, and it will install it automatically from the bird to battery if there is an update
2015-3-6
dundee
Flight distance : 33550 ft
Thailand
Skywolf007 Posted at 2015-3-6 17:59
When I called the phone support, they told me there is no need to leave update files on the SD car ...
yep, also my logic in thinking. cheers
2015-3-6
Joeyend1968
Thanks for the info!!
2015-3-6
DBDagger
Flight distance : 2783205 ft
Leave it on the SD card until your sure all your batteries have been cycled into the aircraft and where able to access the .bin file.
You may get a battery error if you remove the firmware .bin file before all the batteries in your collect have cycled through.
2015-3-14
